Old 11-30-2010
Beneteau 411
prroots is on a distinguished road
Best battery monitor for the buck
I'm planning to upgrade the electrical system on an 'about to be acquired' 34 foot sailboat. I want to keep it simple. So far the system will consist of 4 golf cart batteries, an Air Breeze wind generator, and a battery monitor. Of course, I will also have the stock alternator available on the 27HP Westerbeke. Based upon price and my minimal requirements I have narrowed my choice down to the Bogart Engineering TM-2025RV TriMetric Meter for $173 including shunt and the Victron BMV 600 for $158 including shunt and cabling. I'm favoring the Victron since it has a factor of 10 better resolution measuring amps (ie, 0.01 vs 0.1 amps), much lower parasitic current draw (ie, 4 vs 30 mA), and clean professional look. The one feature I will give up is the ability to measure Voltage of the start battery that the TriMetric offers. I suppose for the price difference I could purchase a standalone Volt meter. I'm interested in receiving opinions about these two meters or any alternatives. Thanks
Pete
Old 11-30-2010
get the Victron. Have you priced marine signal cable recently???
Old 11-30-2010
Maine Sail's Avatar
Ditto! That and a $10.00 DVM from Wal*Mart will tell you volts on the start battery..
______
-Maine Sail / CS-36T
Old 11-30-2010
jrd22's Avatar
Courtney the Dancer
I just installed the Victron this year based on recommendations here on Sailnet and I'm very happy with it. Easy installation and operation, makes me wonder how I got along without it all these years.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 11-30-2010
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
Or for an extra $50 you can get the BMV 602 that monitors two banks. I've not used either of the Victrons, but I know they are well regarded and will probably be installing one next year.
Old 11-30-2010
Just curious, what is the start battery or are you splitting the four GC batteries into two banks. If you're planning on the latter, I wouldn't recommend it. If a single battery fails you'll lose either bank, since you need TWO 6V GC batteries to make a 12 VDC house bank.
BTW, if you price the Tri-metric battery monitor and the cost of the wiring needed to connect it, you're coming pretty close to the price of the BMV 602 SVCarolena mentions.
Old 11-30-2010
oceanscapt is on a distinguished road
Send a message via Skype™ to oceanscapt
Not to hijack the thread, but I've got 3 battery banks on the boat: engine start, windlass, and house. Since about all I can find is dual battery bank units, and knowing that the house has to be on the monitor, which would you suggest putting on the other?
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
Old 11-30-2010
CruzPro makes a couple of models that can monitor voltage for three banks and actual amp-hours on one... so will the Microlog series of battery monitors. BlueSea's VSM422 will do three bank voltage, one bank amp-hours...but will also monitor three tanks IIRC.
Don't know of any that will do amp-hours on three banks.
Old 12-01-2010
Beneteau 411
I will leave the existing 12 V start battery as is. The 4 golf cart batteries will be in a single bank. Since I'm not at the boat, I can't say the make and model of existing start battery. The big uncertainty now is where to locate the 4 golf cart batteries and how to construct a secure box for them. Suggestions?
Yup, it is tempting!
Old 12-01-2010
Are the batteries AGM or wet cell. If they are AGM all you need to do is cover the terminals and strap the batteries down securely, since there is no liquid electrolyte (primarily acid) to worry about. If they are wet cell, you'll want a battery box to contain the acid in case a battery leaks or the boat is knocked down severely.
Without knowing where the batteries are being installed, it is hard to say how to box them in.
Battery Monitor - recommendations JLovett Electrical Systems 8 05-10-2010 07:24 AM
Looking for battery monitor suggestions jarcher Gear & Maintenance 24 04-21-2010 10:53 AM
Battery Monitor - One Bank or Two? montenido Electrical Systems 12 09-27-2009 09:54 AM
Battery Monitor trantor12020 Gear & Maintenance 4 03-06-2009 11:35 AM
Pentametric battery monitor: opinions? Valiente Gear & Maintenance 3 06-26-2008 01:16 AM
