Shore Power went dead help! - SailNet Community
post #1 of 7 Old 12-06-2010 Thread Starter
I have a Pearson 10M (1974) that I plugged into a 30A shore power outlet. Things were working great for a week and I cranked up the heat on my heater yesterday and it went lights out...
I have looked everywhere for a circuit breaker switch any ideas where it would have been? I found a 30A fuse I replaced but that made no difference. All DC systems work perfectly its just the 110V AC shore power sockets that are dead.
Any advice how to locate the fix would be greatly appreciated as its freeezing!
Thanks
newcruiserP10M is offline
post #2 of 7 Old 12-06-2010
MARC2012's Avatar
Did you ck breaker on dock?marc
MARC2012 is offline
post #3 of 7 Old 12-06-2010
QuickMick's Avatar
That has happened to me...only when i ran two heaters off one 'side' of the boat. its fine if i spread the load over two breakers. your heater is probably pullin too much juice. i found my breakers under the galley counter. no idea where yours are, you are just gonna have to search.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #4 of 7 Old 12-06-2010 Thread Starter
I flipped the switch for the power off and back on would there be some sort of master breaker for the whole dock/ marina somewhere?
post #5 of 7 Old 12-06-2010
T37Chef's Avatar
Do you have a battery charger/inverter. My Heart has a breaker on the top?
Shawn
T37Chef is offline
post #6 of 7 Old 12-06-2010
QuickMick's Avatar
I cant imagine you blew a master--did the dock have its lights on?...check by your battery switch, or near the steps to the companionway?
Quinn McColly
Macgregor Venture
post #7 of 7 Old 12-06-2010
There is probably an AC shorepower panel on the boat, which you could have blown. There is usually a breaker on the shorepower post that you could have blown, but that is far less likely, since that is probably a 30 amp breaker.
Have you taken a multimeter and checked the basics... like disconnecting the shorepower cable and testing the voltage at it... If there is no voltage at the shore power cable, then the fault is on the shore side of things. If that is good, the problem is on the boat.
If the problem is on the boat, LEAVE THE SHOREPOWER CABLE DISCONNECTED and check for continuity from the shorepower inlet plug to the main shorepower AC panel. If that is good, then the problem is probably a bad breaker. You can check for continuity between the panel and the outlet to see if the problem lies there... if that checks out... then the problem is the heater.
sailingdog is offline
shore power with out shore power marcusn Gear & Maintenance 33 06-20-2008 03:55 PM
100 migrants reach Fla. shore; 1 dead - The Benton Crier NewsReader News Feeds 0 03-28-2007 05:15 PM
100 Migrants Reach Fla. Shore; 1 Dead - Lompoc Record NewsReader News Feeds 0 03-28-2007 02:15 PM
(AP) 100 Migrants Reach Fla. Shore; 1 Dead - WKRN NewsReader News Feeds 0 03-28-2007 10:15 AM
shore power NewsReader Mass Bay Sailors 0 02-01-2007 10:15 AM
