12-10-2010
Without seeing a wiring diagram, it doesn't sound right here. Is the output DC or AC (that is, is the wind "generator" actually an alternator, or a dc generator? generally in AC systems the black is hot, the white is neutral and the green the grounding wire. In all sources of AC power the green and white are connected. You then run the green to the boat's ground. The green and white should not be connected anywhere on the boat in an AC.
If it is putting out DC then you should have a red (the positive side) a black the negative side) and a green which again is a grounding wire. The black and green both go to the negative bus. The negative bus should have a wire to the negative pole on the battery. The battery will have the negative connected to ground.
Ike
My Boat building Web Site
My Boating Safety Blog
Dont Tell Me that I can't. Tell me how I can!
