Old 12-18-2010
montenido's Avatar
montenido is on a distinguished road
Finding Alternator "Hot" Wire
Hi all,
I just finished a major reconfiguration of my batteries, both location and wiring. I have a new Iota 30 amp charger going to my house bank (3 x 27s), with my back up battery being charged through an Echocharger. Now to complete this set up, I want to run my alternator "hot" wire to the house bank as well. The Echocharger will do the rest.
On a C36 mark 1, does anybody know where the alternator output usually goes? Would it be to the neutral on the battery switch? Can I find it by using a multimeter? If so, a couple of tips on tracking it down would be greatly appreciated.
Thanks in advance, Bill
(I will post pics when I finish)
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 12-18-2010
hellosailor's Avatar
"I want to run my alternator "hot" wire to the house bank as well."
Uh, that's unclear. You want to run the alternator output directly to the house bank as well as what to/or where?
The alternator output lead is usually fairly easy to find, a much larger guage than anything else coming off an isolated post on the alternator. Spot it there, look for the same unique wire at the other end of the harness.
Yes, the alternator output usually goes to a common (not "neutral", that's a term in AC wiring) point on the switch. I've also seen it go directly to the starter, and from there to the switch, as a way of saving wire.
But a little sketch of the whole system might save a lot of words and wonders. A simple misunderstanding on a charging system can lead to "BOOM!" or "ZZZT!" and that can really ruin the party.
Old 12-18-2010
mitiempo's Avatar
On a Catalina 30 the alternator positive output goes to the starter which is already connected to the common on the 1/2/both switch by a reasonably heavy wire. I wouldn't think the C36 is any different. If there is a wire heavier than the others going from the alt to the starter that will be it. If you can see the alternator connections clearly it will be labeled "B+".
Brian
Old 12-19-2010
Maine Sail's Avatar
On the c36 w/m-25 the alt output runs from the alt to the starter post using a few inches of approx 10 ga red wire.
______
-Maine Sail / CS-36T
"Oily Pollution" and "MARPOL Trash" Placards? SEMIJim Gear & Maintenance 16 11-15-2011 09:39 PM
Tanzer 26 - "Starter" or "Build like a tank" asdf38 Boat Review and Purchase Forum 1 07-18-2010 10:24 AM
Nautical version of "Finding Waldo" fullkeel7 General Discussion (sailing related) 5 06-03-2009 04:53 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 16 07-28-2008 06:11 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
