Wiring & Installing A Battery Monitor - Page 6 - SailNet Community
 3Likes
post #51 of 59 Old 06-08-2013
Re: Wiring & Installing A Battery Monitor
Originally Posted by n0w0rries View Post
I'm getting ready to buy a Xantrex Linkpro and came across this thread while doing my research. I'm going to buy a 25' cat6 cable to use for $4.44 instead of their connection kit that costs $120+. What a joke!
Thanks for the great info--hope I was able to give something back!
Oh yeah here's a link to buy the cable: For only $3.60 each when QTY 50+ purchased - 25FT 24AWG Cat6 550MHz UTP Ethernet Bare Copper Network Cable - Gray
thanks Mainesail, great writeup! I know this is an older thread, but......I'm in the process of a LinkPro install, and am making my own wiring harnesd with cat5 cable, do you see any potential issues with this?
wouldrathersail is offline
post #52 of 59 Old 06-10-2013 Thread Starter
Maine Sail's Avatar
The wire for a Link-Pro should be twisted pair. If it is not too late perhaps return it and get a Victron BMV-600. It is much less money, easier to install and does the same thing....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #53 of 59 Old 06-10-2013
asdf38's Avatar
Cat 6 is twisted pair. Of course it's not tinned or designed for marine applications but it's damn cheap and this is a non critical. It seems like a decent fit to me if you're looking to save money and willing to take a chance.
Getting shielded Cat 6 and properly connecting the shield could be even better.
asdf38 is offline
post #54 of 59 Old 06-10-2013
chucklesR's Avatar
I ordered and installed a BMV600s from M.S a couple of weeks ago and installed it the next day.
That's right, the next day. It was that easy.
Since then it's been working absolutely perfectly except for one operator error. It actually performed and self sync'd so well I forgot to tell it I had 320 amp hours not the default 200.
I noticed it was reporting a low state of charge based on amps used/total and percentage - it just took my math addled brain a couple attempts to figure it out.
chucklesR is offline
post #55 of 59 Old 06-10-2013
Thanks Maine Sail! The LP was bought last year when I did our solar panel install, I'm just now getting around to installing it. The CAT-5 cabling is free for me (decommed stuff from work), the sensor wiring/ethernet will be a non-issue for me, however I'm running into another problem with how to run our battery negative system through the shunt, so will have to get someone out to advise anyway.
Great write up, and thanks again for all the great info here!
post #56 of 59 Old 06-11-2013
Glad I found Sailnet
Bene505's Avatar
...I'm running into another problem with how to run our battery negative system through the shunt, so will have to get someone out to advise anyway...
IIRC, connect the shunt directly to the negative terminal of your battery bank. Then connect everything else to the shunt. Nothing else connects to the negative battery terminal except the shunt.
You can get a short jumper made for the shunt-to-negative-terminal, at GenuineDealz.com - Marine Electrical, Boat Wire & Cable, Custom Battery Cables.
Regards,
Brad
chef2sail and mitiempo like this.
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #57 of 59 Old 06-11-2013
Regards,
Brad
Thanks Brad, yes that's how I understand it should be run, however our boat is not set up that way with a common ground. We have 3 banks - two 8D starts - one for each engine, and a 660 Ah house bank. The negatives are jumped from here to there, but not to a common point, which is why I may turn this over to a professional so I don't short the whole dang boat out with this install
post #58 of 59 Old 06-11-2013
mitiempo's Avatar
All you have to do is separate the the negatives of the 660AH bank from the rest and install the shunt as the first in line after the negative post. All other batteries' negatives can be connected after the shunt.
chef2sail likes this.
Brian
mitiempo is offline
post #59 of 59 Old 07-02-2013
Great article. I installed a Xantrex Link Pro two years ago and wish I had seen your excellently illustrated article before laboring and worrying all winter over how to install it. I don't know how I got along without the monitor.
freedoman is offline
Wiring question - Echo Charger and Batt Monitor jarcher Gear & Maintenance 22 07-29-2010 01:35 PM
Battery Monitor - recommendations JLovett Electrical Systems 8 05-10-2010 07:24 AM
Looking for battery monitor suggestions jarcher Gear & Maintenance 24 04-21-2010 10:53 AM
Battery Monitor - One Bank or Two? montenido Electrical Systems 12 09-27-2009 09:54 AM
Battery Monitor trantor12020 Gear & Maintenance 4 03-06-2009 11:35 AM
