Old 02-04-2011
Tree is on a distinguished road
These things (like I pictured) are still on the WM shelf here. I think it is possible that it's (old stock?) in more places than just here. So, anyone out there buying one of these, be careful!
Bottom line, I didn't buy it..... It didn't make sense to me. That's why I brought up the subject here. So, I've ordered it from Defender. I would hope that it's the "newer" model that they send me.
Thanks again everyone.
  #62
Old 02-04-2011
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
did i miss a post i didnt see any mention of using a marine grade breaker they are available in many ratings they can be reset fuses need to be replaced.
12vdc 40a Marine Circuit Breaker - - Product Reviews, Compare Prices, and Shop at Shopping.com
Illegitimus Non Tatum Carborundum.
  #63
Old 02-04-2011
btrayfors will become famous soon enough btrayfors will become famous soon enough
Yep. You did.
Most circuit breakers do not have a high enough AIC to meet ABYC recommendations for direct connection to house batteries.
However, the NEW Blue Sea Systems Series 187 breakers do...they have a 5,000 amp interrupt capacity: 187-Series Thermal Circuit Breaker Panel Mount - Blue Sea Systems
Bill
  #64
Old 02-04-2011
While you do have to replace fuses, properly sized, they're more reliable than a circuit breaker for this purpose.
  #65
Old 02-04-2011
mitiempo's Avatar
Blue Seas recommends against these breakers for high inrush loads like engine starting as well. Fuses are a better choice.
From Blue Seas
Brian
You may post attachments
You may edit your posts
ANL fuse size at battery orientalnc2010 Electrical Systems 9 12-05-2010 06:15 PM
Fuse size for fuse panel? SanDiegoChip Electrical Systems 34 10-31-2010 12:22 AM
how big should the fuse be ? Roberthussey Electrical Systems 5 04-09-2009 04:01 PM
Broken Fuse CaptGum Gear & Maintenance 6 07-30-2007 08:09 AM
Something that looks like a fuse wernervdw Gear & Maintenance 13 03-19-2003 12:05 PM
SEO by vBSEO 3.6.1
