Old 01-30-2011
funjohnson's Avatar
A New Adventurer
funjohnson is on a distinguished road
Adding second Solar Controller
I currently have a Blue Sky 2512ix mppt charge controller coupled with two Kyocera 135 watt panels (270 watt total). I was offered a great deal on a 205 watt Evergreen 12v panel. All three panels are close enough (.5V of Vmp value) that I thought I could just use my current Blue Sky controller. It wasn't until I paid for the panel, brought it home, and started to think about the amps this third panel will make, that I realized it will not work with my 25 amp controller.
After spending money I wasn't planing on spending, I wanted to just connect a low cost controller to my new Evergreen panel. Unfortunately, I'm not sure if the two controllers will play nice with each other. Here is the question:
If one controller senses voltage from the other, would they think the batteries are charged and go into a float stage? Can you have two separate solar controllers at the same time?
1989 Sabre 34II Targa
mjsailing.com
Old 01-30-2011
btrayfors will become famous soon enough btrayfors will become famous soon enough
Probably they will clash. Your solution might be to get a larger capacity MPPT controller which will handle the amperage of the combined panels. Or, forego the most recent purchase: sell it.
The two 135watt panels with a good MPPT controller should be enough for your boat, unless it's a real power hog. Maybe you can find ways to reduce power consumption?
Northern Arizona Wind and Sun has a good primer on MPPT controllers:
Maximum Power Point Tracking Charge Controller
Bill
Old 01-30-2011
funjohnson's Avatar
A New Adventurer
Bill
We are going to the Bahamas this year and just added a watermaker (katadyn 40e). The watermaker, refrigeration, radar, tv and computer all bring our daily requirements to over what the 270 watts could handle. The 135 watt panels are going on the bimini and the 205 is going on the davits.
mjsailing.com
Old 01-30-2011
RXBOT is on a distinguished road
Can you if you would want to create another seperate battery bank fed by the new panel and another controller. That would add some redundancy say if the present controller failed.
Old 01-30-2011
scottyt is on a distinguished road
i second the second bank. figure out the loads and hook up what ever you get out of the second panel and bank. ie if you get 50 amps a day out of the panel and your water maker uses 50 amps hook it direct ( ie normal safety stuff like fuses ). if you do this right you dont even need a big battery, as you are more like using the power as its made, with no real storage needed.
Old 01-31-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Why not call the controller manufacturer(s)?
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Old 01-31-2011
funjohnson's Avatar
A New Adventurer
Funny... I never thought of that simple solution. See, you guys have always been able to answer my questions... I forget about the manufactures.
mjsailing.com
Old 02-01-2011
funjohnson's Avatar
A New Adventurer
Follow-up
I called Blue Sky and was convinced that I needed a larger single controller instead of the two controller option. I ended up buying a Blue Sky SB3024il and will just sell my old 2512ix on eBay. Now I just need to figure out how to fill the void left by the 2512ix in my beautiful teak nav station!
mjsailing.com
Charge Controller for wind and solar cvsheppard Electrical Systems 1 01-04-2011 04:45 AM
Solar controller ?? sailndoug Electrical Systems 4 09-14-2010 02:47 PM
solar controller question granche1 Electrical Systems 4 07-08-2010 06:40 PM
Solar charge controller Jotun Gear & Maintenance 10 04-13-2007 02:22 PM
Best Solar Charge Controller? mmccoy Gear & Maintenance 1 07-28-2004 11:46 PM
