03-02-2011
Termite Fodder
Originally Posted by scottyt
how to test
rig up a cord that will plug in to the dock box with at least 6 plugs. a modded power strip with the plug end and built in breaker removed would work well. then plug in a 500 watt flood light. every 500 watts is a tad over 4 amps.
then just keep plugging in stuff, like heaters, they are nice because they have different levels.
once you get just over the rating of the breaker you need to wait a few mins. as they wont blow right away with just a small over load, it takes a few.
You're serious??
If the breaker isn't working, hopefully the "modded power strip with the plug end and built in breaker removed" won't blow it's internals out at you first..
Besides, this isn't actually testing the breaker's capacity to trip on a short circuit.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
