Old 03-15-2011
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
Originally Posted by eherlihy View Post
My post above got me wondering about what was damaged on Maine's vessel by the lightning strike...
Short story;
- Maine Sail
What? After blowing up $10,000 worth of electronics you're worried about a hundred bucks, or so, of LED's?
Buy the LEDs if they will save power and if you don't need them extremely bright.
Deck light = Halogen
Spot lights = Halogen
becuse you dont use them for long. If you do, then put on the donk.
If you use them for long periods rugularly then you are gunna have a power/light problem more than a 'normal' sailing boat
Sea Life
Notes on a Circumnavigation:
I write with an iPad and its spell checker changes some words. Beware.
  #12
Old 03-15-2011
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Not at all... I'm simply pointing out that there are advantages and disadvantages to LED lighting. There is also no such thing as a free lunch.
  #13
Old 03-15-2011
MaviAtta is on a distinguished road
Rebel LED
I thought this would be a great first post. Two years ago I swapped out most my bulbs for custom LEDs. I made all the lights and put them in thier existing housing. LEDs used to go by 1 watt 2 watt etc etc.. They don't really go by that any more. Now it's all drive power.
My boat is moored in Boston Harbor and traveled over 800 miles and they still work flawlessly and they're about 3 times brighter than the previous bulbs and the LEDs you can buy as replacement bulbs.
Attached are some pictures. Basically, with a resistor, heatsink and LED it's tricky to get all the soldering and such down, but once you do, it really makes ahuge difference.
I just run a rebel star backed with a heatsink and an inline resistor going to each LED. They are drivin with 12v and reduced to 3.4 volts at the resistor. The 3 nav lights work about 8 hours and use about .5 - .7volts.
To make them brighter you can get a bigger heatsink and use more juice, but you wont have to.
I can't post links because it's my first post. I'll be happy to email anyone the pictures.
  #14
Old 03-15-2011
noelex77 is on a distinguished road
I also have built some interior lights using a Cree XP-G R5 and I agree the results are much better than anything you can buy. I would however suggest the addition of a driver rather than a dropping resistor. Its more efficient, with consistent brightness. You can also go brighter without compromising the led life.
You may post attachments
You may edit your posts
Catalina 22 Steaming/deck light question andyjen C22 6 12-16-2011 12:15 PM
Deck light switch DanWampler Hunter 0 02-20-2011 04:56 PM
Deck/Steaming light wiring question andyjen Electrical Systems 15 01-20-2011 11:46 AM
Replacing Deck Light? bbush Gear & Maintenance 10 07-01-2009 10:51 PM
Deck and running light windmutt Jeanneau 1 12-31-2008 12:27 AM
SEO by vBSEO 3.6.1
