shore power - Page 2 - SailNet Community
post #11 of 20 Old 03-21-2011 Thread Starter
One of None
deniseO30's Avatar
Or just give the marina a heads up and ask them to ck other slips make sure they are ok. If and when I ever get back to using marinas I'll be sure to have a tester and or ohm meter on the boat too.
My last project!
deniseO30 is offline
post #12 of 20 Old 03-21-2011 Thread Starter
One of None
deniseO30's Avatar
Oh well.. getting back to the shore power side of my boat. it's very low in priority but I would like to do it right. 3 or 4 cabin lights would be more then adequate. Trouble with bulkhead mounted is the shadows. I like ceiling light myself. That means wire raceways of course.
My last project!
post #13 of 20 Old 03-21-2011
mitiempo's Avatar
Denise
AC lights?
Brian
mitiempo is offline
post #14 of 20 Old 03-21-2011 Thread Starter
One of None
deniseO30's Avatar
Not sure at this point Brian, even if it's worth doing for the little use they would have. I just hate being in the dark and boats are dark in general. But then the use of LEDs should help on the 12 volt side of things.
We should not be using battery charging and battery bank use at the same time right? Example, plugging in the onboard charger instead of shore power and using the dome lights. Maybe LED 12 volt dome lights on the ceiling would be the best choice? I'm getting handy with the Weller soldering gun and looking at those LED clusters as a cheap way to improve the dome lights. (eventually)
My last project!
post #15 of 20 Old 03-21-2011
mitiempo's Avatar
I think the best solution is DC lighting throughout. When away from the dock they run on batteries, and at the dock the same with the charger replenishing used AH.
Brian
mitiempo is offline
post #16 of 20 Old 03-21-2011
Originally Posted by deniseO30 View Post
......We should not be using battery charging and battery bank use at the same time right? Example, plugging in the onboard charger instead of shore power and using the dome lights....
Why not? That's SOP for us.
Faster is offline
post #17 of 20 Old 03-21-2011
mitiempo's Avatar
Myself and everybody I know as well.
Brian
mitiempo is offline
post #18 of 20 Old 03-21-2011
We should not be using battery charging and battery bank use at the same time right? ......
I don't think that is possible to avoid, while plugged into shore power.
Jeanneau 54DS
Minnewaska is offline
post #19 of 20 Old 03-21-2011
Most marine battery chargers are designed to handle running of DC loads whent he batteries are in float stage (as they would be if you're running DC lights while plugged into shore power and your batteries are full). Cheap, bad, or non-marine chargers may mistake this DC load for the battery being in bulk or absorption stage of charging, and that would be bad since it would overcharge your battery.
Also, that polarity reversal switch could be easily replaced with a relay of the same configuration. You could be extra clever and wire the relay coil between the neutral and ground wires. Then, if the polarity is switched, it will energize the coil (exactly the same way the reverse polarity indicator works) which will switch the polarity! No way to forget you left your switch in the wrong position. It probably violates some ABYC codes, so do it at your own risk...
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #20 of 20 Old 03-24-2011 Thread Starter
One of None
deniseO30's Avatar
Well, paid a visit to the local "ahem" home center's electrical dept. the plastic race way and components are on the shelf. for now I'm going with 2 GFIs (one in the galley and one in the head) and one cabin light. Someday I'll put a few 12 volt dome lights or 12 volt florescent on the ceiling.
My last project!
Shore Power went dead help! newcruiserP10M Electrical Systems 6 12-06-2010 12:49 PM
shore power with out shore power marcusn Gear & Maintenance 33 06-20-2008 03:55 PM
!@$%!%!! Shore Power! SEMIJim Gear & Maintenance 30 08-17-2007 12:58 PM
Re: shore power NewsReader Mass Bay Sailors 0 02-01-2007 01:15 PM
shore power NewsReader Mass Bay Sailors 0 02-01-2007 10:15 AM
