Old 03-30-2011
5oclocksomewhere is on a distinguished road
Old Furuno radar, new screen?
I have a mid 80s Furuno model 1720 that is operational. Is there an option for a new and/or LED screen that would plug and play but take up less counter space than the original? (the original looks like a prop from the set of the six million dollar man)
Mahalo!
Old 03-30-2011
r.furborough is on a distinguished road
No - All newer displays are manufacturer specific to the radar and the radars are now digital not analog.
Old 03-30-2011
Bummer. Thanks for the info.
Old 03-31-2011
christyleigh's Avatar
christyleigh is on a distinguished road
.... and to take that - NO - even a step further, even Within the Same Manufacturer they are probably not compatible. I am in the process of replacing my 12 year old B+W Raymarine Radar screen (barely visible and almost useless) with a new model and found out I needed to Also Replace the Radar unit because back in 04 or 05 I think (had to check serial #'s) they ceased to be compatible. The cable WAS compatible ..... BUT, because the new scanner's internal cable attachment required over a foot of extra cable which I couldn't stretch/straighten/reroute to fit I still need another cable it became twice as expensive as I originally thought
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 04-06-2011
limeyrock is on a distinguished road
Is the tube just worn out and dull?, if the CRT unit inside the scanner is a common generic tube (likely) there are options. Probably more expensive than just replacing the whole system though, I've never had need to look into them but it's certainly possible.
Big Screen MFD's -- what's too big? blowinstink Electronics 13 03-12-2010 04:49 PM
Screen enclosure ADMTROX Gear & Maintenance 3 12-27-2009 10:36 AM
Funny Furuno Radar Operation teshannon Gear & Maintenance 13 04-24-2008 01:15 AM
Furuno Radar/ dome compatibility? Tramontane Gear & Maintenance 0 03-27-2006 09:05 PM
Furuno Radar Cable Junction Box? yachtvalhalla Gear & Maintenance 8 03-16-2006 05:47 PM
