04-12-2011
alternator disengaging frequently, .5 seconds at a time
My alternator seems to disengage, for around 1/2 a second at a time, on a regular basis, although usually after it's been running for at least a few minutes.
I thought it may have been caused by my solar panel interfering with the regulator but the same thing happens at night.
I have a Balmar 6 series (70 amp) alternator, and it is hooked up to a incharge/heart interface 3 stage regulator.
After it has been running for a few minutes, every 30 seconds to a minute or so I hear the revs spike briefly. When I look at my voltage monitor it shows the amps and voltage dropping off briefly when this happens.
Anyone know what could be causing this?
The charge is not high - not at float level. This is happening right now and I started the engine 10 minutes ago when the battery voltage was at 12.00 volts.
Thanks for any advice
