  #11 (permalink)
Old 05-11-2011
bud2411 is on a distinguished road
Cool
Originally Posted by Redline4Life View Post
All I really need is to be able to plug in to shore power to keep batteries charged so I don't need to run the engine once a week. Oh, and I'd like to plug in a heater because it's getting cold down here.
R4L
Go to amazon.com
look-up 3000 watt step-down convert. If you search at amazon for"220 110 transformer, use page 2 0r 3 of their responses. $ 64.95. If you blow a fuse (by dropping it, just put in a metal screw, instead (he, he)/ Use i in France every summer. If the 220 outlet isn't a 2 prong you can get plug adapters where you are.
All the best
  #12 (permalink)
Old 05-11-2011
Cool 220 step down converter problem solved!
Originally Posted by bud2411 View Post
Go to amazon.com
Look-up 3000 watt step-down convert. If you search at amazon for"220 110 transformer, use page 2 0r 3 of their responses. $ 64.95. If you blow a fuse (by dropping it, just put in a metal screw, instead (he, he)/ Use i in France every summer. If the 220 outlet isn't a 2 prong you can get plug adapters where you are.
All the best to you in New Zealand.
  #13 (permalink)
Old 05-12-2011
mitiempo's Avatar
Your Newport 41 wouldn't be named "One Flew Blue" by any chance?
Brian
Adding 110V AC shore power Cal28 Electrical Systems 9 07-12-2009 11:30 PM
Getting confused on an electrical system - 12v, 24v, 115V, 220V... labatt Gear & Maintenance 7 10-08-2007 10:05 AM
Wiring Problems I Can Help!12v,or 110v TUNDAR4 Gear & Maintenance 3 05-09-2006 07:16 PM
Combining 110v & 12v charging systems mmccoy Gear & Maintenance 5 08-25-2004 12:41 AM
12v vs 110v reefer for liveaboards abacosol Living Aboard 4 08-30-2003 06:32 PM
