  #11 (permalink)
Old 05-21-2011
hellosailor's Avatar
sis, it would probably help if you posted a link to a picture, and said what kind of boat. If it is a bulkhead connector, the answer may be to remove it but if the wire runs through, you may be able to repair it from below. If you can't see the underside of the wires from inside the cabin of the boat, there's probably a "headliner" on the overhead of the cabin (it isn't a "ceiling" on a boat) and that may have to be partially removed to access the wiring.
A picture's worth a thousand guesses here.
  #12 (permalink)
Old 05-22-2011
citykid is on a distinguished road
I will supply photos
citykid
  #13 (permalink)
Old 05-24-2011
I got the photos. Will try to upload
Sis
  #14 (permalink)
Old 05-28-2011
TropicCat's Avatar
TropicCat is on a distinguished road
In some boats the wiring is actually incorporated into the fiberglass layup when the boat was built. This is the case with my Catalac. In cases where the wiring has either corroded or frayed, I've had to remove the headliner, chop the wires out of the fiberglass and then solder extensions onto them. I use heat shrink to cover the splice. it works just fine.
I also use the "Coax Seal" for thru deck electrical and have had zero problems with water or corrosion. Again, it works just fine as Hello sailor mentioned above.
Tropic Cat
12V electrical connectors 88' PSC34 mondofromredondo Pacific Seacraft 2 11-28-2008 01:00 PM
Sealing the inside of mast wstigg Gear & Maintenance 8 09-23-2008 01:47 AM
wire and electrical connectors online witzgall Gear & Maintenance 10 01-05-2008 12:47 PM
'quick snap' marine electrical connectors?? tenuki Gear & Maintenance 9 06-04-2007 01:29 PM
electrical butt connectors GarrettK Gear & Maintenance 3 11-15-2004 12:57 PM
