05-13-2011
Member at large
Common Ground without an engine...
Hey guys n gals
I am installing an electric motor into my Fiberglass 1977 Orion S&S 35. All I have read about grounding says that the engine's negative is the common ground for both DC and AC. My new motor's shaft is isolated. I thought of connecting a bus to a keel bolt, but then I will also give myself lightning protection this way. Wouldn't a strike potentially frizzle everything connected to the common ground? My raw water intake is bronze and I wonder if I could better isolate the common from the lightning by bonding to this thru-hull? If I put a galvanic isolator on the AC end, will this be enough to keep my thru-hull from getting eaten alive by stray current? Or should I bite the bullet, haul out and install a grounding plate? I don't want to do this....
Also, when choosing a common bus for the whole boat, how do you know what size to get?
Thanks!
Cheers!
Gilligan Stump
s/v lunasea
Please don't google me.
