05-17-2011
Nav lights should be a max of 3% VD. However if you want to wire to applicable US standards then 16GA is the smallest you should use. You're technically fine with 18GA but I would personally not use anything smaller than 14GA in a mast. It gets some of the highest abuse on a boat. VD does not matter for your situation and it becomes more about durability.
______
-Maine Sail / CS-36T
