05-18-2011
h-
"Is this thing user-serviceable at all?"
Everything is user serviceable. Or not, depending on the user.
If you have some electronics experience, by all means, make sure the unit is disconnected from all power, open it up, and check/discharge any capacitors in it, just in case they're carrying 120VAC. If you don't know how to do that, then no, don't even open it up, inverters can carry lethal voltage. Odds are that yours is discharged, but why press your luck?
If you do open it up, yes, look for the burn marks. I have literally seen roaches get into things, shorting them out and causing damage. And capacitors are infamous for leaking. Then there's the diode that simply exploded on a computer board in my computer once upon a time, scared the crap out of me. Yes, there was black burn marks and a vacant space where the diode used to be, made it easy to complain.
Of course, if you don't have a schematic and don't understand the circuits, it is still real easy to replace something and ZAP! have it blow up again. Kinda depends on how adventurous you are. How fast you'd like a working inverter. How much free time you have.
And whether you keep an extinguisher and safety goggles on your workbench. :-)
