05-21-2011
Last first - the charger, regardless of the output amperage, should be charging at about 13.2 for a fully charged battery and over 14 volts if the battery is at 50%.
AGM batteries have a much larger acceptance rate than flooded batteries. A flooded battery of 100 AH, at 50% charge, will accept 25 amps charge until it reaches 80% charge. An AGM of the same 100 AH size at 50% will accept over 100 amps of current until it reaches 80% charge. Lifeline states up to 5 x capacity, or 500 amps. The charging system will work harder and as long as the batteries are under 80% charge the alternator can be at max output. For a small bank this is less of an issue but if the bank is larger in capacity the alternator will run at max output for longer than it is designed to.
For a bank of say, 300 AH from 50% charge to 80% charge is 90 AH. If the alternator is 55 amps it will run at max for over 1 1/2 hours. They are not designed to do this. The solution is an external regulator with an alternator temperature sensor. Ideally an external reg like the Balmar MC-614 is chosen which allows you to dial the alternator back from max output to help. An alternator rated at 100 amps running at 80% is better than an alternator rated at 80 amps running flat out, even with a temperature sensor.
Many alternators have been done in by AGM batteries.
I understand the situation of space - is there no other location for the batteries?
Brian
