06-09-2011
Buzzing from AC panel
Yesterday night, while using around 20 amp's of AC, my main breaker tripped (It is a 30 amp breaker). I have separate 15 amp port and starboard breakers and each was under capacity. When I checked, the main trip was a little warm to the touch (not excessively though). I turned it on and there was some buzzing which in a few seconds turned to some sparking noise together with some oscillations in the amp meter needle. From the back of the panel, I could see little sparks jumping from a main hot post to the bus metal. I turned everything off and unplugged the shore power. The I cleaned the two main posts on the AC hot bus and tightened them. The sparking noise and the amp oscillation was gone but there is still a little buzzing.
Now, I don't remember if that little buzzing was there before. Is that normal? I am thinking of cleaning (Take off the posts one by one, a little sanding to get the slight corrosion off and screw back tight) the whole AC and DC panels. Is that the likely cause or can you think of another problem? Also, any advice on better cleaning these things?
Thanks
1978 Gulfstar 50'
Clark Sailing Dinghy 10'
