  #11 (permalink)
Old 06-14-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Originally Posted by SEMIJim View Post
Okay: Nobody seems to see any down-sides to my design, so I think this is the way I'll go.
Thanks, everybody, for your review and comments.
Jim
Jim,
If you've looked at my previous post link, you'll see the wiring diagram using these two switches. Not much "reinventing the wheel" to do for ya.
Good luck, I think you've found something that will work for you.
Whether you choose to do the switch positions or battery numbering schemes, I encourage you to do a wiring diagram so whatever you do is understandable and recorded. Once you draw it up, I think you'll find the switch position idea isn't so good, logic should apply.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
  #12 (permalink)
Old 06-14-2011
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by Stu Jackson View Post
Jim,
That design is one way to go-about it, but not how I'd do it.
I see little need to ever run the house load from the starting battery. In fact: One of my design goals all along was to prevent the house load from running-down the start battery.
My design will have the house load on the On/Off switch.
The 1-both-2 switch will have its common on the starting circuit, "1" to the house batteries , "2" to the starting battery.
Normal operation will be the house switch On/1, the starting circuit switch on "2"
If my starting battery dies, move the starting circuit switch to "1," to start off the house bank.
If my Echo Charge dies, move the starting circuit switch to "both," combining start battery and house bank, if desired.
Thanks. I think so.
I will document it, for potential subsequent owners.
I can have either both of them on "1" for normal operation (switches moved in opposite directions from one another) or house to "1" and starting to "2." Either one is logical. The question was: Which seems more logical? I could do a poll , but I'm thinkin' the results might end up pretty evenly split.
To me, just reaching over and turning them on/off, I would think identical mechanical operations for both would be more logical. Ideally the 4-position switch would've had "1" clockwise from "off" and "2" anti-clockwise. But they didn't, so I must make a choice.
Maybe I'll do that poll, after all
Jim
s/v Abracadabra
1976 Pearson P30
What's your Battery Bank cvsheppard Pacific Seacraft 4 09-30-2009 07:08 AM
Battery Monitor - One Bank or Two? montenido Electrical Systems 12 09-27-2009 09:54 AM
Dead battery in 24 V bank serdeniz Electrical Systems 5 05-30-2009 11:14 PM
Improved handling in reverse brak Gear & Maintenance 42 09-29-2008 01:27 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 08:00 PM
