  #21 (permalink)
Old 09-14-2011
OPossumTX is on a distinguished road
this is good Information!
I have been curious about the accepted practices for marine electrical installations but haven't searched for it. Now I find most of my questions answered right here.
Thanks!
O'
  #22 (permalink)
Old 09-14-2011
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
OK one more question, but it's still related for the most part. Hope you don't mind!
My alternator is a 90 amp Balmar with ARS-5 external regulator. I don't know what gauge the charging wire is currently. Regardless, what should it be for a 5 foot run to the house bank?
According to the Blue Sea chart that Maine Sail posted, that looks like 4 AWG. But when I use the circuit wizard on the Blue Sea site, it comes out as 6 AWG, even up to 100 amps. Of course it will usually be a lot lower than 90 amps from my alternator.
So how do I size the alternator wire? I know the fuse will be MRBF and I'll size it according to the alternator wire size.
Thanks for the additional help!
-J
1984 Sabre 34 Mk I
  #23 (permalink)
Old 09-14-2011
Maine Sail's Avatar
You actually have a 10 foot run, there and back. Remember all DC circuits are a loop. There should be a negative wire that is a minimum of 4ga and a positive wire that is 4ga. This will still result in a 2% voltage drop or 0.3V drop @90A. So at 14.6 you'd be seeing about 14.3v at the battery. 2ga would be better than 4ga.
In either case the alternator should be grounded direct to the house bank, or a closely located buss, for best performance. It should not just be connected to the engine ground then back to the bank. Most Balmar's are isolated ground not case grounded. This will help reduce any more VD than is absolutely necessary. Both of these wires, neg & pos, should be led to the house bank for the best performance.
Above all else your ARD-5 regulator should sense the house batteries not the alternator but this needs to be done with care and wired properly. This will eliminate any VD issues as the regulator will compensate the voltage. You'll still have VD in the wire but the banks won't see it because the regulator will compensate for it.
You can size it lower than the wire size and still be fine. The fuse should be as close to the batteries as possible. We are trying to get as little VD as possible and that requires large wires. With battery sensing you can get away with smaller wires but bigger is still almost always better.
______
-Maine Sail / CS-36T
  #24 (permalink)
Old 09-14-2011
josrulz's Avatar
Unpaid Intern
Thanks Maine Sail. I just stopped by the boat, and found some interesting details:
First, the current alternator "out" wire appears to be a #10 AWG, and it wraps around the block, and then connects to the starter solenoid. From the starter solenoid, there's a 1 AWG cable that goes to the battery switch on the center post.
Is there any good reason why the alternator would go through the solenoid, or was this more likely a matter of convenience with the wiring harness?
Second, my alternator is only 75 amp, not 90. Though by Blue Sea chart, that's on the line between 4 AWG and 6 AWG, so might as well go with 4.
Third, I can't find a ground wire attached to the alternator that runs back to the ground. I can find a couple wires that supply ground to other things like gauges and the voltage regulator, but it appears that the Balmar is grounded by its mounts. Is this even possible?
If this is getting too far off the topic of fuses, please let me know and I'll start another thread.
Thanks!
-J
1984 Sabre 34 Mk I
  #25 (permalink)
Old 09-14-2011
Maine Sail's Avatar
Typical factory installation..
Only that it is cheap and easy for the manufacturer and when boats came with only two batteries and a 1/2/BOTH/OFF it allowed the user to select where the charge current went. Bottom line it is cheap and easy and builders still do that to this day.
The only thing that hurts by going bigger is the wallet..
Some older Balmar's had a case ground option but most still shipped with a ground stud.. If there is a ground stud on the back of the case make good use of it....
______
  #26 (permalink)
Old 09-14-2011
josrulz's Avatar
Unpaid Intern
...The only thing that hurts by going bigger is the wallet..
Thanks again, Maine Sail! OK, so when I rewire, I can skip the route to the solenoid, and run my 4 AWG output from the alternator directly to the POS busbar or battery--where the MRBF fuse will be. I plan on a 125 amp MRBF for the 4 AWG wire.
I did some more research--I think the alternator is a 9075, which did indeed come with the case ground option. I will check if there is a ground stud though. If there is, I'll run 4 AWG cable to the NEG bus bar.
Thanks again!
-J
1984 Sabre 34 Mk I
  #27 (permalink)
Old 09-21-2011
josrulz's Avatar
Unpaid Intern
Maine Sail, just a couple of quick questions...
First, I have the bus bars and MRBF terminals in hand now, so I've been scoping out where to place them. I've seen that pic of the S34 battery compartment, where you have the NEG bus and shunt along the after bulkhead of the battery compartment. Do you mind me asking--where did you put the POS bus? Is it opposite? That looks like a tight spot on our boat.
I'm thinking of putting the MRBF fuses on the bus bar, only because the clearance above the batteries is tight. They appear to fit, but they are very close.
Second, the POS studs on my batteries are 5/16, not 3/8. Is this going to be an issue with the MRBFs since they're made to mount on 3/8 studs?
Thanks!
-J
1984 Sabre 34 Mk I
  #28 (permalink)
Old 09-21-2011
Maine Sail's Avatar
Water heater compartment works well.. Just drill the wires through the bulkhead.
With some batts they will clear but with most they won't. The buss bar is fine joust route the POS into the water heater compartment.
Thanks!
-J
Many are and Blue Seas does not make a 5/16" MRBF, been round and round with their engineering department on this.
Blue Seas says it is perfectly safe and "acceptable" if your post has a wide enough base to use a 3/8" on a 5/16" stud.. Personally I would rather see a 5/16" MRBF but they simply don't exist..
______
  #29 (permalink)
Old 09-21-2011
josrulz's Avatar
Unpaid Intern
Thanks on all counts, Maine Sail! I really appreciate all you do here and in other forums.
Cheers!
-J
1984 Sabre 34 Mk I
Battery cable sizing micheck General Discussion (sailing related) 0 06-10-2011 04:50 PM
Best way to fuse Battery Tree Electrical Systems 64 02-04-2011 10:12 PM
ANL fuse size at battery orientalnc2010 Electrical Systems 9 12-05-2010 06:15 PM
Sizing battery charger kavakava Gear & Maintenance 16 10-27-2007 05:57 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
