-   Electrical Systems (http://www.sailnet.com/forums/electrical-systems/)
-   -   About to put in wind generator where to connect green ground wire? (http://www.sailnet.com/forums/electrical-systems/75570-about-put-wind-generator-where-connect-green-ground-wire.html)
Mariner777 06-23-2011 04:35 PM
Am about to install my Air X marine generator on the transom of my Pearson 10M. There are 3 wires on the wind generator - am going to run the positive and negatives to my house battery with a short circuit switch to stop the blades in case of extreme winds etc. Can I just connect the green ground to say a ground on my keelbolts? Was reading that keelbolts are used as grounds but I wonder if that might be a bad idea as it could cause them to corrode faster? Otherwise where would be a good place to connect the green ground wire?
SimonV 06-23-2011 07:58 PM
Join the green to the black and wire up as normal.
mitiempo 06-24-2011 11:16 PM
Simon is correct. Keelbolts can be part of a lightning ground but not an electrical ground.
Maine Sail 06-25-2011 07:04 AM
The green wire goes directly to your ships main earth ground point. On most boats this is the engine. On many boats a keel boat is not a sufficient earth ground due to encapsulation or barrier coating. The green wire from the wind gen is your safety earthing wire.
