Originally Posted by Hartley18
FFS..
Just to correct the record: Solar panels and other charging devices output in "watts", people!!... That's Amps x Volts. Over time, it's called "watt-hours".
Only if the voltage is constant (which for a charging device it never is) is it ever correct to talk about AH. And, although, like many charging devices, it may have a "max current output" rating it is never correct to say a solar panel puts out a fixed number of amps (because it simply doesn't - the current output is dependent upon voltage proportional to light level hitting the cells).
To get meaningful amps/amp-hours out of a source of supply, you need something to fix the voltage at a set level. An MPPT can do this; so does a (very) large battery.
We now return you to your regular program....
Programming department here!
You are actually and completely correct.
But W = A * V ALSO means that
A = W / V
So, with a reasonably constant voltage, it's pretty much the same thing, isn't it?
So, given a "nominal" 12V system, albeit with varying voltages from say 11.5 V to 12.8 V, and higher when charging, we come to the very same conclusion.
In fact, the popular battery monitors actually measure watts and watt hours, so we're also in total agreement.
You and others on this thread may be interested in Maine Sail's "Installing a Battery Monitor" article, and my associated "Gotcha Algorithm" article, which pretty much covers the whole measurement and charging and acceptance issues. See ---
Wiring & Installing A Battery Monitor - SailboatOwners.com
We can "argue" all day and night (
) about whether it's better for the OP to run his fridge during the day or at night or whenever he chooses to, and whether it's better to do so when charging or when not.
But the basic, overall, 24 hour period use of POWER that is STORED in the house bank simply doesn't change (very much). Granted, there are efficiencies and other issues, well brought up by these responders to this thread, but here's the result:
"Breaking In" New Wet Cell Batteries
All I'm saying is that real world, parsing the small differences in efficiencies, it really doesn't make much difference. That's the WHOLE purpose of having STORAGE batteries.)
I just came back from a 2 day mini-cruise, and ran my fridge constantly (on 7 and 5 out of 7 on the thermostat). Fridge ran all night, keeping our food at a reasonable temperature, and kept the ice in the evaporator frozen. We have a small solar panel (11Watts) which doesn't contribute much during a cruise, but works fine for offsetting the wet cell battery inherent drain during the week and actually adds a few
amp hours during the week, since it ADDS watts at a certain voltage over time to the house bank. I don't keep our boat plugged in to shorepower when I'm not there. Simple.
Thanks for watching, and I agree, back to Yan Can Cook. Oh, sorry, that's CNG or propane...
Let's not go there...
Thanks again...
Stu
