07-06-2011
Unpaid Intern
Originally Posted by Maine Sail
You don't need a cover but if placing them in the factory compartment that would not qualify as "acid proof".. It could be made as such but would require some serious re-work....
You could build a drop in box out of plywood then have it Rhino Lined. I did that on one boat and they only charged me $20.00 and did it on the tail run of a pick up truck bed. Two group 31's fit nicely in there...
Thanks Maine Sail. That really helps.
I have a couple of Group 29s (came with the boat) in the main battery compartment (in boxes). Still trying to figure out where to put the reserve. There is physical room in the compartment just aft; however, that compartment also has a big access hole so the stuffing box can be reached (the shaft is angled to port). Any battery in there would block access to the stuffing box, which doesn't seem like a good practice! This was a bummer, as I was thinking that the most likely location.
So that got me asking about requirements, etc., because the only way I could fit 3 batteries in my main battery compartment would be if I converted to AGMs (I was planning to stick with wet cell batteries) and even then, only if I skipped the battery boxes. So then I'm thinking the most likely location would be in the starboard cockpit locker, which I'd prefer not to do simply because it's valuable storage space. I can't help feeling like there's some space to be had at the main compartment or nearby that I'm just not thinking of--some other way to approach it.
Anyway, so there's where I am...trying to find a place for more batteries in a Sabre!
1984 Sabre 34 Mk I
