07-24-2011
Termite Fodder
Originally Posted by Girlsailor44
You could have a bad connection behind the battery switch. Another option is sometimes the surface between the cable and the crimped on connector. It may be hard to see the oxidation until you get right on top of it. Check the negative lead from the battery it may go to a junction before it gets to the engine block.
In cars this symptom is frequently a bad connection.
After the bloody thing wouldn't crank for the race this morning, you might (embarrasingly) be right!! It's highly intermittent.
As I posted above, the negative lead is brand new - but the connection onto the earthing relay is mighty suspect - and very hard to see, let alone get at. I'll disconnect the whole bloody thing later in the week and have another go..
To do this properly, I'm going to need to put in washers either side of the multiple oversized crimp lugs connected to all and sundry.. Is stainless ok (I have plenty of those), or should I really get some zinc-plated steel ones?
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
