07-07-2011
Midwest Puddle Pirate
At first glance your calculations make sense, but it's been many, many years since I've messed around with anything like that so my opinion is not to be trusted.
One thing that jumps out at me is your assumption that the alternator will be putting out 50A. While it may be rated at 50A, under most conditions it will be putting out substantially less. Also, if you do run your engine up to speed so you get maximum output from the alternator, you will likely be buying an alternator after a few hours of this. Most alternators are not designed to operate at maximum output for long periods of time.
You also have to consider losses in your inverter. Many inverters are only 85% efficient, so you have to divide your amp requirement by .85. This means you should be looking for 124 amps instead of 105.
How about a little Honda generator in the cockpit?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. John USYacht 27 "Cora Lee"
