09-05-2011
You have many options presented here. LED's are expensive. A bigger battery is probably a good choice regardless of what else you run. AGM batteries have a longer/better reserve rating. Outboards....Several problems here; Your basic 9+ hp outboard "may" charge the battery, but will move a J24 at hull speed at idle, and at idle, will not put out enough to charge the battery and could wiegh upwards of 90lbs. and also require a seperate fuel tank, and the storage for it. Most J24 owners that I know don't want the weight aft, so they remove the motor for racing, and I garantee you will not want to lift a 9+hp motor on and off the back of your boat. I run a 4hp with charging circuit(6 amps), with an on-board tank, and it does charge the battery because you do rev it enough for full output, it wieghs 55lbs. Still not light, but I need the motor to get the boat out and in to the morrage.
My choice for you : bigger battery with solar for back-up.
Best of luck
Kary
S/V Mariah
#49080
