Like Tree1Likes
Old 08-01-2011
WanderingStar is on a distinguished road
12v Outlet Fries Chargers
My 12v outlets have blown fuses on my Garmin plug, (I thought the plug was bad) and now cooked my wife's iphone charger (sorry honey!). Any ideas why? I have two, it happened from both. Could they both have gone bad? Or can the wiring or batteries be responsible? The spotlight works in the same outlet.
Old 08-01-2011
landmineop is on a distinguished road
Send a message via Yahoo to landmineop
Were the chargers designed to plug into 12v dc or were they dsigned to plug into 120v ac. Just wondering.
Old 08-01-2011
12v, car charger types.
Old 08-01-2011
A few minutes with a volt/ohm meter and you can trace out the wiring to find the short. If you don't have one head to Radio Shack and get one.
Old 08-01-2011
kd3pc's Avatar
kd3pc is on a distinguished road
either AC across them, or over voltage...
Old 08-01-2011
deniseO30's Avatar
Lies about her age
12 volt outlets seem to short if the plug is not inserted straight and all the way in. it's happened a couple of times to me.
Old 08-01-2011
btrayfors will become famous soon enough btrayfors will become famous soon enough
Check the polarity and be sure they're negative ground. The chargers and the Garmin would care, the spotlight wouldn't.
Bill
Old 08-01-2011
Maine Sail's Avatar
Bill
I suspect the same as Bill. The red + wire goes to the center pin and negative to the socket walls reverse this and you'll blow many modern chargers...
WanderingStar likes this.
______
-Maine Sail / CS-36T
Old 08-01-2011
Dufour 27 Newb
jaybeegee is on a distinguished road
I had a similar problem and found that my unit was shorted!
Now I have a problem that I cannot find a replacement unit which fits the ca.22m socket on the switch panel i have!
Also make sure you are using appropriate sized fuses (typically 10amp) for the cigarette lighter socket. do a quick calculation by dividing ivide the number of watts by the voltage.
cheers
Old 08-01-2011
hellosailor's Avatar
"12 volt outlets seem to short " That would blow the fuse/breaker to the socket, not the fuse in the lighter plug or device itself.
I vote for a failed regulator in the boat, putting 16-17 volts on the "twelve" volt system instead of 14.3-14.4. Second choice, some AC leakage into the system.
Spotlights are very tolerant resistive loads, you can run 'em for a while at 16-17 volts before they burn out. Versus most electronics, which will become toast at 15.
new GFI outlet with inverter teejayevans Pacific Seacraft 3 09-19-2010 12:40 PM
12v DC outlet installation kwaltersmi Electrical Systems 7 08-24-2010 11:40 AM
Loo outlet location Hartley18 Gear & Maintenance 10 08-05-2010 09:05 PM
Outlet issue dch Electrical Systems 14 11-07-2009 12:42 PM
Fried Outlet? newportknots Gear & Maintenance 2 08-25-2008 08:17 AM
