08-20-2011
Originally Posted by PaulfromNWOnt
It's a safe statement to say battery acid doesn't freeze. I've seen frozen batteries, but thos have all been extreme circumstances.
Fully discharging a battery is hard on it. Leaving it in that state doesn't help. If you plan on using that much power, then increase the size of your bank. A bunch of batteries wired in parallel will have a lower replacement cost in the long run if you don't kill them then a single battery that you hammer on.
That being said, gel cells seem a little more tolerant to abuse. It would be up to you to determine if that tolerance is worth the premium.
At, roughly, what temperature do GEL batteries freeze?
I dont know if what I have been doing to my, current cheapo, battery is called "fully discharge". Sometimes I use it until it fails and then I charge it. I try to get it on charge as soon as possible but it can take a day until I do so. You mean that I should avoid doing this, right? Then I need something to control when to stop. What is the percentage that one should stop draining a battery?
