Old 09-09-2011
CapTim is on a distinguished road
Question Does the Starting battery also need to be wired behind the Victron BMV-602S shunt?
Hello! Here's another wiring question for you experts...
I'm redoing the wiring on my new-to-me 35 year old boat. Part of that is the battery banks, and part of that is installing a battery monitor. I've settled on the Victron BMV-602S, as it is nicely priced, is apparently easy to install, and does the job it needs to do with a minimum of fuss.
So. It's clear that there can be no loads behind the shunt on the negative battery terminal of the house battery. (By behind I mean, of course, refers to the battery side, not the 'rest-of-the-boat' side).
However, don't I want to connect the negative post on the start bank to the negative post on the house bank? And if so, do I make that connection on the boat side of the shunt or on the house bank side?
In a related question, where does the 'ship ground' go? I assume the 'ship ground' is going to be the engine in most cases, right?
My concern would be that if I connect the ship ground behind the shunt, and then some other piece of electrical equipment also is grounded to the ship ground, then that load would not be monitored by the Battery Monitor, right?
So, to recap, two questions:
1) _If_ I'm supposed to connect the negative side of both banks together, do I connect them ahead of the shunt or behind it?
2) _If_ I'm supposed to connect one or both battery banks to the ship ground (engine?), do I connect them ahead of the shunt or behind it?
Thanks for all the help!
... or I'm wrong.
Living aboard, currently in the Chesapeake
O'Day 37, still new to us
Old 09-09-2011
mitiempo's Avatar
The house bank's negative connection goes to the shunt first. Any connection to any equipment or the engine block is after the shunt. After the shunt I would install a bus for the house negative, start battery negative, and from there go to the block. Do not wire the start battery negative behind the shunt.
Here is a diagram from the manual showing how the start battery is wired with the BMV-602 so it will read voltage of the start battery.
Does the Starting battery also need to be wired behind the Victron BMV-602S shunt?-1.jpg
Brian
Old 09-09-2011
Excellent! That's exactly what I needed... Thanks Brian!
... or I'm wrong.
Old 09-09-2011
Maine Sail's Avatar
Yes the start battery should go on the "load" side of the shunt not the battery side. If the banks are combined via a parallel switch of BOTH feature you WANT that outflow or inflow of current from the lower or higher charged bank to be read.
When you "combine" banks of different charge levels current flows in or out between them until they "equalize" and the current stops flowing. The only way to read this is to wire the start/reserve battery to the load side of the shunt.
______
-Maine Sail / CS-36T
Old 09-09-2011
Ahh.. that was the part I was missing in my head. Well, that and the diagram from Brian!
... or I'm wrong.
Old 09-09-2011
mitiempo's Avatar
On the other hand if you use your house bank for house loads and engine starting you can leave the other battery as an "emergency" battery. This battery can be wired to the bus after the shunt and Victron's diagram I posted is the proper way to wire it. The BMV-602 will read the start/emergency battery voltage which is all you need to know. With this exception the data on the Victron relates to the house bank, which is the one you need the info on. There would not be any need to ever combine the battery banks. If the house bank was not enough to start the engine the emergency battery by itself will do the job.
Brian
Tags
battery monitor , victron
New Victron Battery Monitor is DOA montenido Electrical Systems 5 03-02-2012 05:57 PM
VICTRON BMV 600 Battery meter BELLATRIX1965 Electrical Systems 3 11-07-2009 10:11 PM
Link Battery Monitor Shunt Installation SteveInMD Electronics 0 07-22-2009 02:42 PM
Starting battery Alden68 Gear & Maintenance 25 04-12-2007 12:24 AM
Starting Battery vs. House Battery GarrettK Gear & Maintenance 18 10-26-2004 10:58 AM
