-   Electrical Systems (http://www.sailnet.com/forums/electrical-systems/)
-   -   Need a four conductor plug replacement (see image) (http://www.sailnet.com/forums/electrical-systems/78617-need-four-conductor-plug-replacement-see-image.html)
josrulz 09-11-2011 04:53 PM
Hi all,
This connector is for our mast wiring, near the base of the mast. It's 4 conductors. The one in the pics below is falling apart, and the rubber sleeve is disintegrating. I'm looking for something either identical or functionally similar, ideally water resistant since water comes down the mast. We need to unplug it when the mast comes out, but otherwise it stays connected most of the time. Anyone know what this plug is, or have a suggestion for an alternative? See pics:
http://farm7.static.flickr.com/6167/...3a7ea444_z.jpg
http://farm7.static.flickr.com/6183/...828efbeb_z.jpg
Thanks for your help!
-J
PorFin 09-11-2011 05:06 PM
Jos,
Trailer light wiring plug -- available from almost any auto parts store, WalMart, etc.
http://t3.gstatic.com/images?q=tbn:A...H3LN3Jdw54ECBQ
josrulz 09-11-2011 05:22 PM
Thanks PorFin. I did think of that, but would prefer a connector where the my own wires go into the plug. With the trailer plug, I'll need to have four connections which will end up inside the mast, unseen, and wet. I'd like to reduce the number of connections, if at a possible.
The connector I have has screws on the side, and the wires are inserted and tightened to the connector.
Of course, if I can't find an alternative, a trailer plug might be the way to go.
Thanks,
J
josrulz 09-11-2011 05:50 PM
Answered my own question, but PorFin helped, because it got me looking at more trailer plugs. The exact plug that's on our boat is a Cole Hersee M-115, available from lots of vendors. Thanks again!
-J
Pic of a new one:
http://www.colehersee.com/assets/pro...tors/m-115.jpg
PorFin 09-11-2011 05:54 PM
-J
Pic of a new one:
Ha! Gotta love it when this happens (an all too rare occurance, if my history is any indicator...)
Just curious here -- how does the C-H plug tackle water/weatherproofing? Do you just slather on sealant or liquid tape after you insert your primary wire?
josrulz 09-11-2011 05:56 PM
Ha ha! Same here. Sometimes posting here and evening just exchanging a post or two with one person helps me sort through and figure something out. Thanks again!
-J
fryewe 09-12-2011 01:02 AM
I have one of these plugs adjacent to my tabernacle to unplug and plug in mast electrical loads when stepping and un-stepping the mast. I waterproof the plug with electrical tape, three wraps, tightly pulled to stretch the tape as the wraps are made. I make the wraps three inches up and down the wiring on both sides of the plug. Never had a problem with this method in 28 years. Also protects the plug from UV. Only had to replace the plug once in the boat's 33 year life.
