Old 09-27-2011
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Figuring my electrical requirements. 2 Q's?
I am getting my tiny sailboat ready for a two week cruise I plan to take in the next few months down in the Keys. I am revamping my electrical system and I want it to be adequate for my needs, although they are minimal in my opinion.
I am figuring up my daily amp hours and I am stumped on how to determine how much I should allow for charging my electronics like my handheld vhf, cell phone, video camera, and my mobile tablet. I will be using them moderately, possibly one full discharge per item per day except for the vhf.
Any guesses? Any ideas on how to figure that out?
I believe I will be charging them through cigarette lighter sockets since I have a 12v system only.
Right now I am at about 12 amp hours per day in my total usage of things like: gps, auto pilot, anchor light, nav lights, and led interior lights. (I plan on using a manual bilge pump)
My other question is:
I hope to be able to charge my batteries up with a solar panel or possibly two. I would rather stay away from having to use shore power unless I had too. Right now I have a new solar panel that is rated at 2 amp hours a day which isn't much.
If my power consumption was about 14 amp hours a day, them I should have about 16 amp hours a day capacity in my solar panel system them correct?
Thank you all for your opinions!
Small is beautiful, simple, cheap, and easy......
Visit my website
! Lots of useful info and sailing videos.
Old 09-27-2011
Perithead's Avatar
Montgomery 17
My solar panel is a:
Sunsei solar charger 400, 400mA, 15V (6W)
Maybe my assumptions on the solar panel output could be off?
Visit my website
Old 09-28-2011
mitiempo's Avatar
Hi
That is a pretty small solar panel - really built to maintain batteries when they are not in use rather than charging them after use. Your assumptions are correct as in a sunny climate you usually figure 5 hours at full panel output. There is loss because you have to put more AH into your batteries than you use - about 110%.
Your estimate of 12 AH per day sounds low - how are you estimating this?
Do all the items you wish to charge have 12 volt chargers? If so they will have a sticker on them that lists amps and voltage.
How large is your battery bank? Normally it should be sized so you can go for 2 or 3 days without charging - you can't rely on solar every day. And in the third day you want to be able to recharge the battery (batteries) fully if possible after several usage.
Brian
Old 09-28-2011
Perithead's Avatar
Montgomery 17
I came to my 12 amp hour usage by calculating the amps used by each item and multiplying that by how many hours I expect to use each item on a 24 hour basis.
As I said earlier my requirements are minimal on my 17' boat consisting of an autopilot, gps, nav and anchor lights, interior led light and then charging various electronics. I think that's pretty basic really and a lot less than most boats. I am a bit of a miniamlist, I do a lot of backpacking so I more or less camp on the boat.
Visit my website
Old 09-28-2011
Perithead's Avatar
Montgomery 17
My battery bank as of now is one regular deep cycle wet boat battery (same size as a car battery). I plan on upgrading it if need be.
I will check on my chargers this afternoon and report back.
Visit my website
Old 09-28-2011
noelex77 is on a distinguished road
Your assumptions look reasonably correct to me. My first boat was similar and I used about 14AHrs day.
There are a couple of ways to measure or guess the consumption of the VHF cell phone etc.
1. Measure it with a multimeter (clamp on is easiest) it will vary through the charge cycle, but you can estimate an average.
2. Look at the devises battery capacity convert this to the equivalent in AHrs at 12v then add a fudge factor for the charges inefficiency (I would multiply it by 2)
They vary a lot but a starting figure might be (to recharge from a flat battery assuming 12v chargers))
VHF 3 Ahrs
Cellphone 1.5 Ahrs
Video camera 2 Ahrs
Tablet 5 Ahrs
Old 09-28-2011
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
Good topic! This is very close to our setup...
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
Electrical requirements ext222 Electrical Systems 33 10-21-2011 10:38 AM
Figuring Battery Capacity docbob5707 Gear & Maintenance 10 07-06-2008 01:50 PM
Electrical System requirements for Bahamas cruising Pelham Cruising & Liveaboard Forum 6 12-18-2006 08:57 AM
Help figuring our which Irwin this is? trecksail Boat Review and Purchase Forum 9 02-01-2005 02:50 PM
figuring distance from Lat/lon c172guy Seamanship 8 06-10-2004 04:02 PM
