Like Tree1Likes
  • 1 Post By Bene505
Old 09-28-2011
jeflaba is on a distinguished road
Upgrading the AC/DC System in My Cal31
I retired and moved aboard my 1979 Cal31 in July 2010. I have quite enjoyed the freedom to leave the dock and sail anytime I want and have spent many happy days in local anchorages this last year. However, as the 5 year warranty on my two batteries approached I found myself calling for Vessel Assist to get a jump start more than once.
I have to say, I was not good about checking the water levels on the two group 27 batteries. I had upgraded these from group 24s when I bought the boat and replaced the "clip-on" automotive style charger with a nice 8 amp Redicharger. However, the charger was in the cockpit locker and I seldom checked the gauge. I had a sneaky suspicion all was not well. Also, I had recently rebuilt my windlass upgrading the motor from 700 watts to 1000 watts so I knew I needed more amp hours. Also, I wanted to run my vacuum cleaner while at anchor to clean up all the dirt and sand I was bringing back from my hikes ashore. Finally, a test showed my alternator had given up the ghost and was not charging my batteries.
I had spoken with my boat mechanic and he agreed to work with me on upgrading my systems. His solution was a Xantrex Freedom 1800 charger/inverter. This would charge the batteries at 40 amps using a "smart" three stage charger which varied the amps and volts to give the fastest and safest charge and to maintain the batteries at the correct "float" level. The charger would provide all the necessary DC for lights, etc. while connected to shore power (or my ancient Honda generator) and automatically switch to provide AC, up to 1800 watts, while off the grid.
To power the inverter I upgraded to group 31 AGM batteries. Yeah, no more unstrapping the batteries to check the water levels. The combined batteries give me 204 amp hours or a little over 100 while never going below 50%. I also added a group 24 starter battery connected to the house bank with an isolator so I would never have to worry about starting if I ran the house bank down.
To charge these batteries we installed a Balmar 100 amp charger. This has the added advantage of putting a good load on my little 14 hp Universal diesel so it doesn't run cold - and heats up my water faster! Last, I added a Xantrex LinkLite battery monitor - like a super fancy gas gauge for my batteries. It will tell me the voltages for both the house bank and the starter battery, the input/out amperage, the number of amp hours used and a bar graph showing the percent of charge left.
After three weeks cruising in Channel Islands National Park I feel I have made a good investment (of about three B.O.A.T. units). One thing I know I need to do is replace my 1.5 amp anchor light with a low draw LED unit. I have purchased a small 700 watt microwave which, although I have yet to find a good place to stow it while underway, is a handy device for heating leftovers. I love being able to clean up spills with the vacuum cleaner. I have even used my electrice tea kettle but the draw on this (1500 watts), even for a short time, really draws down the batteries.
The new alternator will, for example, take me from 56% to 92% charge in about a hours running which gives me enough hot water to wash dishes and shave and "french" bathe. The Xantrex charger takes a little longer to bring the batteries up to full but the three stage charge (bulk/adsorption/float) is completely automatic. I love not having to worry about whether I need to check the water level in the AGMs. And knowing the engine will always have power to start is priceless.
Upgrading the AC/DC System in My Cal31-charger-inverter-batteries-switch.jpg   Upgrading the AC/DC System in My Cal31-starter-battery-new-mount-isolator-upper-right.jpg   Upgrading the AC/DC System in My Cal31-new-gauges.jpg   Upgrading the AC/DC System in My Cal31-new-alternator.jpg
Old 09-29-2011
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Nice set-up.
My first reaction reading this is that a bigger inverter/charger can power a standard microwave. But you've found a lower-powered one that works. Good on you. Our microwave sucks our 330ah house bank down rapidly, but it's useful for exactly what you describe. (The toaster uses more amps than the microwave though. I took it off the boat after getting a toaster that fits over the propane stove.)
Second thing, you got the battery monitor. It's the most useful upgrade we've put on the boat.
Do you have a fridge yet? That will really use-up the amps and will require a nice big solar panel or two. LED interior lights could come first (conservation is cheaper than more generation). Once you get the solar panels, you won't need the dock very much at all.
Retired too. Does that mean you'll be cruising full time for awhile?
Good luck and enjoy. Post pictures.
Regards,
Brad
jackdale likes this.
Old 09-29-2011
jackdale's Avatar
jackdale will become famous soon enough
It does look good. I would recommend some wire ties on the harnesses and I would suggest labels on the wires.
One white wire appears to be terminated poorly. (yellow connector)
Re: High wattage appliances.
I have sailed boats with microwaves and toasters. I run the engine when I use these. (I do the same with an anchor windlass)
The electric kettle can be easily replaced by a good old fashioned one on the stove.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Upgrading engine hp jswwrites Gear & Maintenance 20 09-14-2006 08:19 PM
Upgrading Spars Tom Wood Gear and Maintenance Articles 0 12-01-2003 07:00 PM
Upgrading Spars Tom Wood Cruising Articles 0 12-01-2003 07:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 07:00 PM
Upgrading a ''93 Hunter 27 dpierce Boat Review and Purchase Forum 5 09-05-2001 01:32 PM
