10-01-2011
the pointy end is the bow
I discovered that the boat has a DC generator and I am pretty sure it came that way from the factory.
Are you talking about a separate stand alone generator, or the belt driven generator on the ship's engine? Old cars and tractors had DC generators on them and they were replaced with alternators, which got more power at lower RPM.s
Also the boat does not have AC, can an 5000 watt inverter run AC or would I need to get a new genset?
I can't imagine a battery bank large enough to be able to power a 5K inverter that would run AC. 5000 watts requires around 400 amps of battery power.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
