10-13-2011
I'm not an expert but it is my understanding that such a small charge (35 watt = maximum of about 2.5 amps) is not going to hurt such a large battery bank even if it is at full charge. So, you are ok there.
Regarding #2. Yes, that is correct. However; 11.3 volts is pretty much a totally discharged battery. Discharging to that level is not good for them. I suspect a tiny little fan would take many weeks to discharge such a large bank so perhaps not an issue. Is it possible to change the voltage level at which the load is cut to something around 50-60% capacity (depending on the state of your batteries, around 12.3-12.4 volts)?
Totally different situation but.... I leave a medium size fan (~1 amp draw) running all the time in my boat in Florida with an 80 watt panel and ~400 amp-hour battery bank.
We learn from experience that men never learn anything from experience. — George Bernard Shaw
