  #11 (permalink)
Old 10-19-2011
mitiempo's Avatar
1. Negative bus bar
2. Distance is not an issue but wire size is. I would size for minimum loss - 3% or less.
3. I wire all battery cabling the same size - most often 2/0
Brian
  #12 (permalink)
Old 10-19-2011
ctj1950's Avatar
ctj1950 is on a distinguished road
Rev A
How do I size a new alternator? Should it be based on the battery bank size.
1976 Gulfstar 43 CC Ketch
  #13 (permalink)
Old 10-21-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
The West Advisor: Alternators
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
  #14 (permalink)
Old 10-21-2011
Maine Sail's Avatar
Originally Posted by ctj1950 View Post
Rev A
With the ACR wires at 2/0 you no longer technically need the fuses on each buss, if you don't want them.
These fuses are there only to protect the wire. If the wire shorted the battery fuse would blow and you'd be protected from a fire.. If you want to keep them feel free but it could save some money by using the fuse on the bank as your OCPD..
______
-Maine Sail / CS-36T
charger/inverter selection and updating electrical system on a Gulfstar 37 rmeador Electrical Systems 5 08-24-2010 09:05 PM
Updating The Head Freesail99 Gear & Maintenance 4 01-02-2008 05:20 PM
Updating an Older Boat rennisaint Gear & Maintenance 20 10-27-2007 11:20 PM
Updating Icebox to Refrigeration chuck711 Gear & Maintenance 6 02-23-2003 07:41 AM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
