10-27-2011
What has been done, appears to have been well done....and the Blue Seas gear is top rate.
Others will chime in, but I would simply add the 110v shorepower and a decent battery charger/inverter....there are many, but I would use a midline Xantrex unit.. I would get the pure sine wave unit.
A small 110 volt panel to support some convenience outlets and the charger may be all you want. If you see yourself needing more 110 volt gear, now would be the time to assess how many and how much current you think you will need.
Best of luck
