Old 11-05-2011
pogosmoke is on a distinguished road
outboard alt kit/rectifier questions
I recently bought a 25 cc and it has a 9.8 2006 4stroke. I would like to upgrade the electrical system from a single battery charge at dock system to something more capable to handle small tv/laptop/ more lighting/ possibly a small heater. I can purchase a alt kit and a rectifier kit for the outboard for about $150 could I hook this to maybe a 3 12v parallels battery bank with an inverter and have a good capable self charging electrical system? Or should I just by a Honda gen? Which would cost a lot more.
Old 11-05-2011
NautiG's Avatar
NautiG is on a distinguished road
Pogo,
You gotta do the math as to how many amp hours you will be consuming and producing. I googled the alt kits you mentioned. The one I saw looked like it put out about 7 amps. That would probably be enough to help power a laptop or small flat screen tv. As to the lights and heater, I would convert to led lights and a propane heater.
You don't say how you use your boat. If it's just weekend trips, I'd go for the kit. If it's a liveaboard, I'd spring for the honda generator. Also, have you checked that your outboard doesn't already charge the battery and doesn't need an add on kit?
Scott
Gemini Catamaran Split Decision
Old 11-06-2011
tommays's Avatar
The outboard will put some back in BUT is not going to be able to keep up with big loads and even the generator would have to run a LONG time
Normally you would do and energy budget and make the house bank big enough to last your weekend needs and recharge back at the dock
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-09-2011
It would just be for weekends. So if I have say 4 deep cell golf cart batteries fully charged and the kit for the outboard do you think I would have enough juice for a night or two? On the propane heater these are safe for enclosed areas? No carbon monoxide issues?
Old 11-10-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Forget the electric heater idea. Propane or alcohol or some other fuel is the way to go. A bank of four golf cart batteries is too large for an outbard charging system. A single group 27 or 31 deep cycle should be plenty for running a few lights, small TV and laptop for a weekend. If you can start with a fully charged battery, the outboard kit will help keep the battery reasonably charged. For longer trips, note it will take a number of hours to bring it up to full charge if signficantly discharged.
Old 11-11-2011
Don Radcliffe
donradclife is on a distinguished road
make your own for less than $5-- my tohatsu has the coils already installed, and their $300 charging kit is essentially one of these:
25A, 50V Full-Wave Bridge Rectifiers - RadioShack.com
Dinghy/Outboard Questions Please TSAKUS Gear & Maintenance 13 05-13-2011 02:18 PM
Diesel outboard questions flyfisher Gear & Maintenance 3 08-07-2010 03:41 PM
Outboard questions for a mooring bouy SeattleSail General Discussion (sailing related) 1 06-11-2010 03:34 PM
Outboard or not... 71Irwin32 Gear & Maintenance 68 12-09-2009 04:34 AM
Outboard questions Chompy Gear & Maintenance 10 06-04-2006 07:36 PM
