Old 11-08-2011
jimd333sail is on a distinguished road
Shore power won't engage
I have an '82 O'day 28 with a 30amp shore power system. In the last few years the double throw switch to connect to shore-side power has worked at first intermittently, depending which dock I used. Now it won't engage at any dock. The boat is primarily a mooring queen and occasionally I like to use the battery charger to fully top off the batteries.
A neighboring boat suggested that I may have a grounding problem. My questions are, where do I begin to find a grounding problem in the AC system; and do those double throw shore power switches "fatigue" or fail that often? There is power to the vessel and the polarity is light is extinguished (as should be). The DC ground is fine.
Thanks for any help you can provide,
Jim
Old 11-08-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Yes, Jim, they do sometimes eventually fail. Everything has a "useful life." Just buy another one and install it.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Old 11-08-2011
mitiempo's Avatar
Or it could be a loose connection that is causing a short between the hot and neutral wires somewhere that is causing the breaker to trip. It might be just doing its job.
I don't think the ground can have much to do with it. The breaker controls hot and neutral only.
Brian
Old 11-09-2011
If I show 120V on the back side of the double throw switch, then I should assume it is the switch? And where is a good place to go for that switch?
Thanks
Old 11-09-2011
mitiempo's Avatar
Any good marine store should have a 30 amp double breaker. Make sure you buy a proper double pole breaker - you can't combine 2 singles for this.
ANCOR MARINE CE World Double Pole Circuit Breakers for 110V AC at West Marine
Yes if show 120 volts between hot and neutral I would suspect the breaker.
Brian
Old 11-09-2011
I'll get on it and let you know how it went. Thanks to all, Jim
Old 11-26-2011
GaryHLucas is on a distinguished road
Okay, I have lots of shore side electrical experience. On shore you never, ever, not ever break the neutral through a switch or circuit breaker of any kind. There are lots of good reasons for this. Can someone point me to a reference on marine AC that explains why the neutral wire would be broken by a switch on a boat, as mentioned above?
Thanks,
Gary H. Lucas
Old 11-26-2011
mitiempo's Avatar
For a main AC switch the hot and neutral are both opened. That way it there is a reverse polarity issue in the marina you can be assured that there are no hot wires. The individual circuits are single pole, opening the hot wire only on most boats. I say most because a friend has a French built Beneteau CC36 that uses double pole breakers for every AC circuit.
On a metal boat double pole switches are often used for all circuits, AC and DC, so when it is off it is guaranteed, for stray current reasons.
Brian
Shore Power H and E Gear & Maintenance 3 10-02-2011 11:42 AM
Shore Power sailguy40 Gear & Maintenance 4 05-01-2011 10:53 PM
shore power deniseO30 Electrical Systems 19 03-24-2011 09:52 AM
Non-US Shore Power coyotejack Cruising & Liveaboard Forum 6 03-21-2011 10:37 AM
Re: shore power NewsReader Mass Bay Sailors 0 02-01-2007 01:15 PM
