11-18-2011
Senior Moment Member
Originally Posted by btrayfors
Twelve volts isn't going to shock you.Bill
Obviously you have never set the timing on an old style ignition distributor.
I have been zapped more than once by a leaky spark plug lead when twisting the distributor. It was comparable to what hits you when you get tickled by a defective 110 outlet or switch.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
