01-21-2012
Depending on the configuration of your compression post/mast step it may be possible to run your wire down through the mast step into the cabin on a deck stepped mast rather than do the exposed on-deck connection. You'll probably have more luck with a compression tube rather than a solid post, but even so there may be room to drill a hole for the wire - perhaps into a head compartment to 'hide' it a little. This would keep the pass-through out of the weather and avoid the tripping hazard and the need for a waterproof connector. If the mast is down now it's a good time to check into that.
In-mast will definitely look cleaner..
1984 Fast/Nicholson 345
