more battery questions - Page 2 - SailNet Community
 1Likes
post #11 of 22 Old 12-24-2011
Originally Posted by mitiempo View Post
Bill
With a 1/2/both switch each bank can be a house bank so I believe both should be fused.
Brian,
Definitely. But the start circuit fuse needs to be larger than a house fuse in order to avoid nuisance blows when starting the engine. On a small diesel, I believe 300-400A is appropriate.
And, if you're going to regularly start the engine using the BOTH position (i.e., from the house battery bank), then you'll also need a large 300-400A fuse in that circuit.
Cheers,
Bill
btrayfors is offline
post #12 of 22 Old 12-24-2011
mitiempo's Avatar
I would try not to fuse above the wire's ampacity, although up to 150% of that is ok. ANL fuses are unique in blow point though. 2/0 as an example is good for about 280 in engine spaces. A 275 amp ANL has a blow point of 420 amps after 500 seconds and much more for shorter periods of time. That should not have nuisance blows. I haven't had any issues with nuisance blows fusing starting circuits.
I would never start from the BOTH position. If one battery can't start the engine switch to the other - especially with AGM batteries.
Brian
mitiempo is offline
post #13 of 22 Old 12-24-2011
Brian,
Yes, I know about the ANL fusing delays and ratings. Still, I'd go with a larger one, since I have personally blown a 150A or 250A ANL on my 4-108....can't remember which. No problems since I've started using a 400A ANL over 5 years ago, and my wiring is 2/0.
Look at Maine's circuit diagram. If you're going to use the house batteries for starting, you HAVE to use the BOTH postion (and leave the ON-OFF switch OFF, isolating the start battery).
Bill
post #14 of 22 Old 12-24-2011
mitiempo's Avatar
If you use the extra switch Maine suggested you are correct - I just use the 1/2/both switch and skip the extra switch.
400 amps is less than 150% of 2/0 wire's ampacity if it works for you.
Brian
mitiempo is offline
post #15 of 22 Old 12-25-2011 Thread Starter
Thanks Bill, Brian, Maine, everyone, and Merry Christmas. It sounds like the Echocharge is a better fit for what I want to do. I'll also pick up another battery switch to use for the starting circuit as drawn by Maine.
The 2 existing batteries will be wired in parallel to make the house bank and I'll get a new starting battery. I'm going to try and sneak out there later today and take some pictures and measure things. As I get closer to a final layout I'll try to post a drawing.
Thanks again
Fitz
Fitz87 is offline
post #16 of 22 Old 12-25-2011
mitiempo's Avatar
Sounds like a good plan. Merry Christmas.
Brian
mitiempo is offline
post #17 of 22 Old 12-25-2011
Stu Jackson's Avatar
Here's a reference that supports what Bill, Brian and Maine Sail have been saying (I just put it all in one place ):
Basic Battery Wiring Diagrams
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #18 of 22 Old 12-25-2011 Thread Starter
Thanks Stu. That's a great link. I'm going with option 2 and the Echocharge.
I did get some pictures today and have some research to do now on the existing alternator (Motorola?) and regulator (spa creek?) to try and figure out what kind of output it has.
My shore charger is a Xantrex "Truecharge 10 amp TB". It looks almost new and has 8AWG wires going to the house bank location.
I'll use 2/0 for all the high current/starting runs and ANL fuses as suggested.
Thanks for all the help everyone. It's going to be a lot of expensive wire, (and lugs, and fuses, and busses, and switches...) but like most of these projects, in the end, I'll have learned some things I didn't know I didn't know!
Fitz87 is offline
post #19 of 22 Old 12-25-2011
mitiempo's Avatar
The best place to buy wire, cables, and lugs is Genuinedealz > Marine Wire, Boat Wire, Boat Cable, Marine Grade
If you don't have the proper crimp tool they will install lugs on the 2/0 for $1 labor each. The only disadvantage is that you have to measure the proper lengths when ordering.
Brian
mitiempo is offline
post #20 of 22 Old 12-25-2011
davidpm's Avatar
curious as to your current cost estimate.
davidpm is offline
Battery Questions sundog01 Electrical Systems 1 05-18-2009 05:06 PM
Battery questions Popeyensweetp Electrical Systems 4 02-22-2009 11:23 PM
More battery theory questions hertfordnc Gear & Maintenance 1 04-22-2008 08:47 AM
Charging / Battery questions wduncan50 Gear & Maintenance 17 01-16-2008 03:51 PM
More Battery Questions.... Alden68 Gear & Maintenance 26 04-16-2007 06:44 PM
