01-08-2012
Beneteau 411
Originally Posted by btrayfors
It's not enough to bother with, and might confuse your charger.
Better to get a bigger charger. Best value would probably be the Iota DLS-75/IQ4. This is a 75A charger which will put out that current as long as needed, and the EU2000i can handle it.
BTW, in terms of time to get a full charge, remember that after about 80% state-of-charge (SOC) for flooded batteries, the charge efficiency drops to less than 50%. In other words, you have to "put in", e.g., more than 50AH in order to increase the battery's capacity by 25AH. It takes time.
Bill
Thanks. I would much rather have a 75 or 80 Amp charger, but I don't want to give up my nice Xantrex TrueCharge 2 40 Amp charger which works great when on shore power. Any ideas on how to arrange a second, larger charger for use with Honda? It should be quite inexpensive since the cost would be in addition to the Honda. I'm wondering if some type of direct connect, portable system wouldn't be the way to go. Maybe the charger could be inexpensive if I'm not using it to float. My idea would be to charge from SOC of 50 up to 80% on a daily basis. Any ideas on how to get the job done economically?
Pete
