Like Tree1Likes
Old 01-23-2012
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Electrical panel material suggestion
I'll be doing some electrical upgrades this year, and replacing a few of our AC and DC panels with new ones that are not the same size/configuration. The old ones are currently mounted in teak. I'll need to cover the original holes up and start anew for the new panels, so I was planning to use some sort of thin black material for this. Then I'll cut the appropriate holes and mount the new AC and DC panels in them.
Any suggestions for material? I was thinking black Starboard 1/4", but that's a little thicker than I'd prefer, and somewhat more flexible too. Any alternatives that are easy to acquire?
Thanks!
-J
1984 Sabre 34 Mk I
Old 01-23-2012
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I took out one teak panel completely, and then used 1/4" oak for the facing for the new 12V panel. The new panel would have fit in the old hole, but the oak lightens it up dramatically.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 01-24-2012
josrulz's Avatar
Unpaid Intern
Thanks for the suggestion. In our case, it won't be "framed", and it'll be an overlay on top of the existing teak. That's why I'm looking for a thin black material that's stiff. I'm sure there are lots of options--I'm just not that familiar with what's out there.
-J
1984 Sabre 34 Mk I
Old 01-24-2012
mitiempo's Avatar
Matt finish laminate - Arborite or Formica - available in dozens of solid colors including black and multiple shades of white.
Brian
Old 01-24-2012
rugosa's Avatar
rugosa is on a distinguished road
We used to use tinted acrylic/lexan (paint back side black to retain polished look). You'll need the right tools to avoid damage. The New Interstate Plastics has Starboard and other materials that are suitable for marine use. I used to built custom panels for commercial marine use with acrylic but I think there is more material variety available today. Printing has also come a long way in the last decade. Rather than labels you can design the face and have it printed right on the material for a real crisp professional look.
Old 01-25-2012
josrulz's Avatar
Unpaid Intern
Thanks for the suggestions, everyone!
1984 Sabre 34 Mk I
Old 01-25-2012
tommays's Avatar
A carefull drawing and a local watejet cutting place will do a nice job on any material
PaulfromNWOnt likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-10-2012
Waltthesalt is on a distinguished road
rebuilt my electrical system. Because of space limitations off the shelf panels didn't work. So I used a black plastic from a marine electrics store for the panel fronts and project boxes from radio shack for the back. i used aluminium piano hinges for the front panel so it could open. To keep front switches etc manageable I built connection buses and fusing into the box behind the front panel. The box allowed me to do this. It also met ABYC requirements that there not be exposed connections behind the panels.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Old 02-10-2012
h20man is on a distinguished road
I redid mine, with a custom black anodized aluminum panel.
I used free software from Front Panel Express for the design, sending the work directly to Front Panel Express, and now and have a great looking panel (ok my judgement ). They also allow an option for doing lettering on the panel.
They can give such a 'good' deal, as you are the one doing the work laying out the panel, and you are responsible for any problems.... as they use your work to program their CNC machines....
Last edited by h20man; 02-10-2012 at 10:18 PM. Reason: edited to show that panel was produced by front panel express....
Old 03-11-2012
harborhobo is on a distinguished road
Re: Electrical panel material suggestion
If you want a truly professional result, check out Frontpanelexpress.com. They have a downloadable CAD software that is fairly simple. I laid out the panel the way I wanted it with the cutouts for the instruments I wanted. I then spec'd 3 mm black anodized aluminum. I got 2 panels made to order and delivered for $120. Install isn't complete yet, but when it is, I will post the pix. Gonna look great!
New electrical panel saillife Electronics 7 07-21-2011 12:15 AM
Best suggestion for a gasketing material to separate steel and aluminum? Valiente Gear & Maintenance 8 07-16-2009 11:49 PM
Main Bulkhead Material Suggestion jbibb Sailboat Design and Construction 2 04-21-2008 03:29 PM
solar panel suggestion jimmd Gear & Maintenance 3 01-03-2008 12:34 PM
Electrical Panel whathree General Discussion (sailing related) 2 05-24-2006 10:33 AM
