03-16-2012
Re: Panel mount USB power port
Sounds like you have the solution you're looking for, but if I had seen this thread earlier (it was created back in the day when threads were automatically marked as read if you didnt get to them in time), I would have offered the same cig lighter advice.
The cig lighter, which our kids don't even know was originally for lighting cigarettes has more use than a USB. You may want to power other devices intermittently.
The standard iPad charger runs at 2.1 amps and the iPhone at 1 amp. They are interchangeable, but you will naturally get different charging rates. I have a cig insert with two USB outputs, one at each of those amps. In fact, it will also convert the 24v electrical system onboard the aircraft.
I've used it many times and it works as effectively as plugging it in at home.
Now, if you can explain why modern aircraft still come with ash trays? (seriously some do) I tell all passengers, if they would like to smoke inflight, they should kindly step outside.
Jeanneau 54DS
