Shore power vs battery while at slip - Page 2 - SailNet Community
post #11 of 14 Old 03-22-2012 Thread Starter
sailingcal21's Avatar
Re: Shore power vs battery while at slip
Thanks all, good to know. I don't have a reefer...yet, and am upgrading all my interior lighting to LED so my DC consumption will be fairly light. Unless of course, I've got "the Marley" cranked up.
Scott
Scott
s/v Karma
Short Pump, VA
1981 O'Day 34
"No matter where you go, there you are."
sailingcal21 is offline
post #12 of 14 Old 03-22-2012
Is it lithium batteries that will retain a memory of not discharged routinely? Maybe NiCad. Someone will know.
In any case, i don't think there is a standard wet, gel or agm house battery that doesn't actually prefer to be fully charged for its longest life potential.
Jeanneau 54DS
Minnewaska is offline
post #13 of 14 Old 03-22-2012
Wandering Aimlessly
PBzeer's Avatar
I keep a small (easily stowable) desk lamp on board for extended time at the dock. I also have a heat lamp, with the silver surround, that I put a regular bulb in to hang over the range, during those times. For a one or two night stay, I don't use them.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #14 of 14 Old 03-28-2012
asdf38's Avatar
Originally Posted by hellosailor View Post
Scott, if your 12v loads are light enough so that the charger is really powering them and the batteries are just watching the show, then there's no downside to doing it that way.
OTOH if your loads are actually pulling down the batteries, that's still using up discharge cycles. In which case I'd just beef up the charger to prevent that.
How does the Bob Marley song go? "No AC, No Cry..." ? :-)
Right and a way to check would be to monitor the voltage. If you turn off the charger you'll see the voltage from the batteries alone. If when the charger is on the voltage stays above this then any power you're drawing is off the charger. If it goes below then you're pulling some current from the battery.
asdf38 is offline
shore power battery charger - need recommendation pegasus1457 Electrical Systems 7 10-20-2009 07:13 PM
shore power battery charger samhamt Gear & Maintenance 12 06-22-2009 06:53 PM
shore power battery charger samhamt Gear & Maintenance 1 06-21-2009 03:53 PM
Need slip for 3 months, maybe longer, western shore Trekka Chesapeake Bay 7 06-27-2008 04:36 PM
Re: shore power NewsReader Mass Bay Sailors 0 02-01-2007 02:15 PM
