Old 03-22-2012
tomperanteau's Avatar
Crotchety Old Member
tomperanteau is on a distinguished road
Sunforce 12 Volt 10 Amp Controller
Anyone used one of these? Any opinions?
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1969 Crealock/Columbia 36 Sloop completely refitted in 2000 and new Yanmar in 2006.
  #2
Old 03-23-2012
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Re: Sunforce 12 Volt 10 Amp Controller
My impression was that it is cheap stuff, just a regulator to prevent overcharging. No three-stage, no change from bulk to float, just a cheap brute-force regulator.
If that's all you want, great. OTOH Genasun makes some MPPT charge controllers, real controllers with 3-stage charging, about $100. You'll get more power out of the panel AND more life from your batteries. Downside is, it will cost a bit more.
  #3
Old 03-23-2012
bassviking is on a distinguished road
If you have under around 140 watts of solar panel the Genasun 10 amp mppt controller might be your best bet to ge the max out of them. If you have between 140 and 240+ or so watts you should probably look towards a 15 amp mppt controller such as the Moringstar Sun Saver 15a MPPT or the Blue Sky Energy 15-25a offerings. Those are around $200-$250.
You may post attachments
You may edit your posts
Replacing 12 volt batteries with 6 volt justonemoreproject Electrical Systems 11 03-15-2012 09:13 PM
Thoughts on Nicro vs. Sunforce solar vents? ilikerust Gear & Maintenance 22 03-06-2011 09:31 PM
Sunforce trickle charger fordo Gear & Maintenance 1 05-24-2010 05:54 AM
Mixing 6-volt and 12-volt Batteries? captainfrank Gear & Maintenance 3 11-08-2008 11:33 AM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 05:41 PM
SEO by vBSEO 3.6.1
