Backfeed Error - SailNet Community
post #1 of 6 Old 03-30-2012 Thread Starter
Red face Backfeed Error
I am hoping for an answer to a backfeed error. I was recently attempting to charge my bank of deep cycle batteries with my Honda 2kva generator when my Freedom 20 inverter/charger experienced a backfeed and shut down. The charger is monitored by a Link 2000 monitor inside the boat. If the invert button was pressed on the monitor instead of the charge button could this have caused the Freedom to experience a backfeed when the Honda was started up to charge the batteries? As you may gather I am a "newbie" to many things electrical on boats. Thanks
mgmh 58 is offline
post #2 of 6 Old 03-30-2012
mitiempo's Avatar
Re: Backfeed Error
How have you connected the Honda?
Brian
mitiempo is offline
post #3 of 6 Old 03-30-2012
Stu Jackson's Avatar
Re: Backfeed Error
With that size charger on your Freedom 20, you could well be exceeding the output of the Honda. Try the Power Share feature on the Link:
Power Share feature on Link 2000
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #4 of 6 Old 03-30-2012 Thread Starter
Re: Backfeed Error
Hi Brian,
The Honda is connected to the shore power outlet on the boat via a shore power cable. The current is fed to a 240v to 110v step down transformer before it enters the charger.
Stu, thanks for the link.
Michael
mgmh 58 is offline
post #5 of 6 Old 03-31-2012
Re: Backfeed Error
I just learned about scribd from the catalinaowners.com 'site. You can download some good stuff:
30 Amp Shore Power - SailboatOwners.com
see reply #7
post #6 of 6 Old 04-01-2012 Thread Starter
Re: Backfeed Error
Hi Stu,
Thanks again. Very useful information. I should be able to figure out why it happened.
Cheers
mgmh 58 is offline
Tags
battery charging , honda generator , link 2000
Server php error message cupper3 Announcements and Suggestions Box 4 12-01-2010 07:43 PM
Why am I getting error when trying to .. Petar Gear & Maintenance 1 09-10-2008 08:37 PM
Worst navagation error davidpm General Discussion (sailing related) 26 07-09-2008 10:34 AM
Error Rainy9 Cruising & Liveaboard Forum 5 05-06-2008 02:21 AM
GPS ERROR JEFryar Seamanship & Navigation 5 05-21-2002 04:43 PM
