Starter Battery replacement, advice needed - SailNet Community
post #1 of 5 Old 03-31-2012 Thread Starter
Senior in age only!!!
centaursailor's Avatar
My system has two identical 10 year old barreries, not rated in AH. Labled as663 type with a reserve capicty 88 mins?
My needs are simlpe, I run the auto pilot ST1000 a lot, vhf radio, basic instruments and incandesent nav lights.
Currently one battery is not charging so will need replacement, other is fine and engine starts first time.
Also have the one, two or both switch for selection and charging.
Whats my best and simplest solution.
All practicle suggestions welcome, am fairly handy but only have basic electrical experiance.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #2 of 5 Old 03-31-2012
mitiempo's Avatar
Re: Starter Battery replacement, advice needed
Probably the least expensive solution is to buy a starting battery - that is what you probably have now. Should be able to get a good group 24 start battery for $60 or less.
The other option is to use your good battery for starting and get a deep cycle battery for house loads.
Brian
mitiempo is offline
post #3 of 5 Old 04-01-2012 Thread Starter
Thanks Brian
Sounds practicle.
Reckon I,ll go for a deep cycle house battery and keep the existing as the starter.
Are the gel or AGM worth the extra price in this situation.
Safe sailing
post #4 of 5 Old 04-01-2012
mitiempo's Avatar
No. I would stick with flooded. Not only are they a lot less expensive, the charge voltages for flooded are different from agm and gel - especially gel. Gel can last a long time but they have to be charged at the correct voltage and overcharging will cause them to fail. Agm need charging fully as often as possible - 2 or 3 times a week. In these respects flooded batteries are more tolerant. And definitely the best value.
Brian
mitiempo is offline
post #5 of 5 Old 04-01-2012 Thread Starter
Thanks again,
Looks like I,m be sorted with a few bob to spare.
Safe sailing
Advice on adding starter battery waterwks4me Gear & Maintenance 2 02-03-2012 02:02 PM
advice needed...2 bank battery system working as one? twisted23 Electrical Systems 10 02-11-2011 12:58 AM
Light indicator circuit needed when using starter battery macduff Electrical Systems 3 07-12-2009 10:51 PM
Starter Battery HHJ Gear & Maintenance 3 06-22-2004 05:27 AM
Starter or House Battery? rrobar Gear & Maintenance 2 12-30-2003 03:56 PM
