Breaker for AC - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 7 Old 04-19-2012 Thread Starter
mitiempo's Avatar
Breaker for AC
I installed a Blue Seas main AC panel on a boat today. I thought some might want to see the original innovative arrangement. Single pole 30 amp in a metal candy box. Protecting a 15 amp circuit. Oh, and it was lying in the bilge.
Brian
mitiempo is offline
post #2 of 7 Old 04-19-2012
Stu Jackson's Avatar
Re: Breaker for AC
A great use for an Altoids box!
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 7 Old 04-19-2012
Re: Breaker for AC
Gotta love the Altoids tin!
I build my ten volt reference source into a mini Altoids tin. Cheaper to buy it filled with Altoids than to buy panel boxes, and more fun to eat, too.
hellosailor is offline
post #4 of 7 Old 04-19-2012
Maine Sail's Avatar
Re: Breaker for AC
Not much surprises me any more but that one definitely takes the "creative" cake..
This one was "engine cranks slowly".... Vice Grips are NOT crimpers, especially for a wire with upwards of 3000A of current behind it... A tug of less than about 12-14 pounds of force pulled it right out... A "proper" crimp on wire this size should easily lift the entire weight of two to three grown men or more.....
This was a single hose clamp on a leaking sink drain seacock... But hey that hardware store clamp saved him twenty seven cents....
Batteries mounted far to low in the boat and "submerging"...
This incorrect use of a "dimple" crimper left a live dangling 12V wire....
Plastic wire tie in engine space failed. Lucky this boat had battery bank fusing.
Soldered connection failed at the hard spot from solder creep and brittleness. This left a hot wire in the bilge which then ate through every seacock, thruhull and the boats outdrive and it finally sank......
You can still see some remains of the crimp terminal. These soldered wires also were left dangling due to an improper termination..
These devices are NOT safe for the current people try to pull through them on boats. This one nearly caught fire but the connection failed shortly before that happened. Factory installed fuse on the inverter never failed.
Silvio likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 7 Old 04-20-2012
tommays's Avatar
Re: Breaker for AC
Every used boat i have owned i found it MUCH cheeper and faster to just chuck it and start over as it was endless
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 7 Old 04-20-2012
Re: Breaker for AC
By "These devices are NOT safe for " I take it you mean all Chinese electronics, rather than small inverters.
What you see as a problem with the fuse not blowing, I see as some engineer's attempt to prove you CAN "fix stupid". With some collateral damage, but that's unavoidable.
post #7 of 7 Old 04-20-2012
Maine Sail's Avatar
Re: Breaker for AC
I simply do not feel 150+W 12V outlet inverters are safe for marine applications and I strongly urge customers to avoid them. The sockets on most boats get soo corroded they can't pass 2A safely let alone 15A. Most 12V sockets sold in chandleries are rated at just 10A anyway and a few are rated at 15A. A 150W inverter at 80% efficiency can pull about 15A. With corrosion on the tip, which is a VERY SMALL contact area, they get hot and melt like the one below. This is the third melted 12V outlet inverter I have come across. Usually the owner saying "Hey can you put a my inverter back together the tip unscrewed and I can't get back together?" They can't get it back together because the plastic has melted and distorted.
On one boat the guy was running a 400W inverter through 14GA wire and a 25A breaker at the panel. Wire was melted and kept tripping the breaker........
______
Testing a breaker. L124C Electrical Systems 28 03-10-2011 12:58 AM
breaker box QuickMick Gear & Maintenance 4 03-26-2010 04:06 PM
breaker box QuickMick Gear & Maintenance 18 12-09-2009 10:03 AM
Circuit Breaker drynoc Gear & Maintenance 8 11-14-2007 10:15 AM
Tie Breaker km2x Racing 2 07-13-2006 12:35 AM
